LT77 stuck in 4th
Quagmire
Two weeks ago I fitted an LT77 to my 90 that I rebuilt myself after the last box starting grabbing 4th and not wanting to come out easily. All was well with new box, and it has been bedding in nicely.
Tonight I did my 500 mile oil change, and that went fine. Found nothing untoward in the oil, just fine iron filings stuck to the magnetic drain plug.
Drove the 25miles home from my parents to my house, the shift was getting better all the time... I was actually beginning to enjoy driving it again.
Until I got to a roundabout and wanted to go from 4th to 3rd. Found I was totally stuck in 4th.
I was only a mile from home so have made it back and parked up, and no amount of jiggling can get it out of gear. Clutch in or out, engine on or off, transfer in low/neutral/high...
Seeing as my last box did this , and my rebuilt box has been fine with not a single crunch or bang could this be something to do with the selector mechanism? This is the only part that is common to both boxes.
Help!
Thanks
Jamie
I think your only option is to dismantle it and see what has seized!
You could try filling the selector housing with penetrating oil and likewise with the ports for the detent springs - as it's most likely to be the selector rods seized in their tubes as that's one of the likely spots for water ingress. Leave it over night then see if you can 'wiggle' the rod enough to free it up?
Si
Thanks for the reply Simon- was in dire need of a tumbleweed smiley until you came along :)
Disassembled this evening. Look what I found:
The little pawl thing had dropped out, think perhaps the synchro had shot up too far? Appears to have worn the selector fork as a result of it being held in that position. At least I hope thats the cause- it definitely didnt look like that when it went together!
So any ideas why that might have happened? I don't think I replaced those bits on 4th- if they were worn I suppose they could get sloppy enough to allow this to happen?
this part is UKC3530L, we have many problems with these due to them being too soft, so much so I recently conducted a small experiment,
I bought some from 5 different sources including genuine and sent them for hardness checking, results were :
Bearmach 146-154 HV
Allmakes 139-153 HV
Britpart 144-151 HV
Genuine LR 127-135 HV
Evolution 803-838 HV
it turned out the evolution ones were genuine LR old stock, ie genuine when the 77 was in production, all the others inc genuine were aftermarket untreated mild steel,
note genuine was about 10 times the price of the others and was the same aftermarket part,
unfortunatly evolution don't have any more so I am having to make my own from another supplier,
when you put it back together I would suggest getting some out of an old 77 and putting a file across them to check they are hard
Dave
I imagine it's far easier to get them made out of the correct steel in the first place so they can be hardened properly than to 'fix' the ones currently available. Obviously not practical for the man in the street but a sensible route for Ashcrofts, especially as they have to warranty their finished boxes.
As a side effect it also means there will be a source for the man in the street :) Assuming Dave decides to start selling the ones he has made that is.
  • 2 years later...
Hello...I'm suffering the same issue as the pictures attached show...
Quagmire, did you find out the long term solution to this? How did you end up fixing this? New baulk rings, slippers, and springs? Was this a problem with input shaft freeplay?
  • 4 years later...
Update: I got replacement slipper pads from Ashcroft's and replacement parts from Carddocks. Rebuilt my gearbox in 2014. The gearbox has been running strong ever since.
The reason why this happened to me was that I had a habit of resting my hand on my gear lever while in 4th gear. Doing this rapidly wears out the clutch fork and baulk ring. Once the baulk ring wears out, the synchro sleeve will over-travel and the slipper pads will jam the synchro sleeve.
I don't do that anymore :)
