muddyplugger Posted August 9, 2006 Share Posted August 9, 2006 Really sorry to be thick here, but I'm a self confessed idiot regards automotive electrics. I am going to wire in my new horn and it is to have a 20amp in-line fuse. My question is what size wire do I need for such an installation? I have digested the information on the internet and I am still not much the wiser!! I believe a 10 guage wire may be correct, but physical size is that? Is it 10mm or 20mm? And I presume I measure the wire itself and not the pvc sleeve too? I really need to be educated Quote Link to comment Share on other sites More sharing options...
minivin Posted August 9, 2006 Share Posted August 9, 2006 if it's fused at 20Amp's, I take it it is only pulling about 15A ? For a reasoanble safety margin I'd go for the following from Vehicle Wiring Products based on a 15A constant draw: Ref 25. Thinwall 28/0.30mm, 2mm2, 25amps http://www.vehicle-wiring-products.co.uk/V...les/cables.html That way you got a bit of a safety margin till the fuse blows Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted August 9, 2006 Author Share Posted August 9, 2006 Wow thats a quick reply! Cheers Minivin, I'll take a look! Anth. Quote Link to comment Share on other sites More sharing options...
western Posted August 9, 2006 Share Posted August 9, 2006 (edited) from the link above Ref 16. Thinwall 32/0.20mm, 1mm2, 16.5amps. 26p per M. £13.93 per 100M reel. Plain colours also available in 30M reels @ 4.29. Typical applications: Side & tail lights, alarms, reversing & rear fog lamps, electric aerial, HORNS general wiring. more than good enough as a horn is intermittent /occasional use only. with a 15amp fuse Edited August 9, 2006 by western Quote Link to comment Share on other sites More sharing options...
minivin Posted August 9, 2006 Share Posted August 9, 2006 As I said, I take it it is only pulling 15A if you got a current meter cable of 25A then it would be worth doing a test so that you can match the fuse and wire to the true current usage, does the horn have noted on it what the current it draws? Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted August 9, 2006 Author Share Posted August 9, 2006 As I said, I take it it is only pulling 15A if you got a current meter cable of 25A then it would be worth doing a test so that you can match the fuse and wire to the true current usage, does the horn have noted on it what the current it draws? Thanks for this info guys in reply to minivin, the horn (Nautilus compact air horn) does not say what current it draws, but it has a 12V 30A relay and says to wire a 20A in-line fuse from the battery. So the reference of: 'Ref 25. Thinwall 28/0.30mm, 2mm2, 25amps.' is the likely wire. There is a wiring diagram, so now armed with the correct materials I am able to follow the instructions to wire this thing in! Fingers crossed! Quote Link to comment Share on other sites More sharing options...
minivin Posted August 9, 2006 Share Posted August 9, 2006 Thanks for this info guysin reply to minivin, the horn (Nautilus compact air horn) does not say what current it draws, but it has a 12V 30A relay and says to wire a 20A in-line fuse from the battery. So the reference of: 'Ref 25. Thinwall 28/0.30mm, 2mm2, 25amps.' is the likely wire. There is a wiring diagram, so now armed with the correct materials I am able to follow the instructions to wire this thing in! Fingers crossed! ah air horns that'll be why it needed to be a higher current due to the blower, yup the wire guage sounds fine now Quote Link to comment Share on other sites More sharing options...
