Juz Posted November 21, 2011 Share Posted November 21, 2011 Hi All, The heater fan on my My '96 90 has stopped working. In order to help me diagnose the problem, does it run through a relay (and if it does, where is it)? I know it's a numpty question, but I don't have my Haynes book of lies with me. Thanks Juz Quote Link to comment Share on other sites More sharing options...
will4x4 Posted November 21, 2011 Share Posted November 21, 2011 perfect timing hey - i cant help but ... i bought a marine fan from ebay for about £15 wired it in to the exsiting plug and literally just jammed it down the heater in duct after taking the lid off on the wing.... works a lot better than standard - and was a 15min bodge. of course you could install it much better Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 21, 2011 Share Posted November 21, 2011 Will, which one have you got? As that's what I'm planning on doing to mine as I reallllllly can't be bothered pulling the heater box out to get the fan working again!! Quote Link to comment Share on other sites More sharing options...
will4x4 Posted November 21, 2011 Share Posted November 21, 2011 it looks just like this: http://www.ebay.co.uk/itm/Rule-4-In-Line-Bilge-Blower-Marine-Fan-240-/160685544681?pt=LH_DefaultDomain_0&hash=item25699ad4e9 But someone sells them here in the UK Quote Link to comment Share on other sites More sharing options...
g90 Posted November 22, 2011 Share Posted November 22, 2011 i belive you after a bilge blower fan, this mite help http://forums.lr4x4.com/index.php?showtopic=62485&st=0&p=541432&hl=heater&fromsearch=1entry541432 George Quote Link to comment Share on other sites More sharing options...
wermy Posted November 22, 2011 Share Posted November 22, 2011 There is a 3 pin plug on a cable connected to the unit. If you apply 12v to the connections you should get the two speeds. Additionally there is the 3 connections behind the speedo that match the ones on the unit. So no there is no relay just a wiper switch that also operates a bowden cable to open and close the main air vent from the wing. Just had all my wiring apart over the weekend trying to put a newer loom in and had to trace all these wiggley bits down. According to my notes it should be fed by fuse 4 as you have the later type blade fuses at that age of vehicle Quote Link to comment Share on other sites More sharing options...
Litch Posted November 22, 2011 Share Posted November 22, 2011 Sometimes the fan can get clogged up or just plain stuck, remove the inlet duct and spin it with your fingers and if you find any debris while you are at it remove it. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 22, 2011 Share Posted November 22, 2011 My fan is all seized Quote Link to comment Share on other sites More sharing options...
Tanuki Posted November 22, 2011 Share Posted November 22, 2011 Sometimes the fan can get clogged up or just plain stuck, remove the inlet duct and spin it with your fingers and if you find any debris while you are at it remove it. On my 90CSW I once had a heater-blower-problem. Investigation showed that the local mice had packed the intake-pipe and inside of the fan with nuts and berries. --Tanuki. "BADGER!!!" Quote Link to comment Share on other sites More sharing options...
Ruuman Posted November 22, 2011 Share Posted November 22, 2011 I can still recommend the bilge pump fan, done the mod to a couple of trucks now and it makes a hell of a difference. I think my standard motor has just about packed up now on my truck, the bilge fan still provides more than enough air! Just fitted and eberspacer for the cold mornings too Quote Link to comment Share on other sites More sharing options...
Juz Posted November 23, 2011 Author Share Posted November 23, 2011 Fan is free, easily spun by hand. I may (oops, embarassed) have checked the wrong fuse, I read it as Fuse 5, so I'll check that first and report back. Cheers Juz Quote Link to comment Share on other sites More sharing options...
western Posted November 23, 2011 Share Posted November 23, 2011 there is a resistor in the heater case, just under the plate where the wiring goes into the motor, maybe that's causing the non working problem. Quote Link to comment Share on other sites More sharing options...
Juz Posted November 30, 2011 Author Share Posted November 30, 2011 there is a resistor in the heater case, just under the plate where the wiring goes into the motor, maybe that's causing the non working problem. Can I test this 'in situ' or do I need to drill out the rivets and remove the resostor? Juz Quote Link to comment Share on other sites More sharing options...
western Posted November 30, 2011 Share Posted November 30, 2011 probably better to remove the rivets & then you can test resistor directly. this is it blower motor resistor Quote Link to comment Share on other sites More sharing options...
TurboBen Posted November 30, 2011 Share Posted November 30, 2011 could also be the switch, just had the same problem on my own and a friends 90 and was switch on both. Quote Link to comment Share on other sites More sharing options...
backstop Posted December 8, 2011 Share Posted December 8, 2011 I had the same problem last winter. Tried all the usual things but eventually found the multi-connector to the fan (near the back of the passenger side wing, under the bonnet) had had water in it and the whole lot had burnt out. It just fell to bits when I wiggled it. Just cut all the wires out and used bullet connectors to join it all up again. The power feed looked a bit black but it has held up OK. 5 minutes to fix but 3 hours to find! Quote Link to comment Share on other sites More sharing options...
