smokinv8 Posted December 6, 2011 Share Posted December 6, 2011 (edited) Having managed to bend my HD steering arm (in front of axle, drag link?) when out with the j33p club at 7sisters recently I decided to fit the Gwyn Lewis drop arm conversion kit at the same time. Everything came off fine but on trying to put the new disco drop arm in place we quickly realised that the arm I had wasn't the correct fitment onto the splines to my 6 bolt steering box. I phoned Gwyn and he confirmed that it would only fit onto a 4 bolt box. So... I had to straighten the HD bar I already had and refitted everything as was again. But my question now is, not wanting to waste the kit I bought are there any differences between the 6 bolt box I have and a 4 bolt box? Are the hoses/connections the same too? And as it will no doubt be easier for me to source, is a Disco 6 bolt the same? Edited cos im an eejit Edited December 6, 2011 by smokinv8 Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted December 6, 2011 Share Posted December 6, 2011 You better reread your post and replace 6 with 4 wherever appropriate as it makes no sense as it is..... Quote Link to comment Share on other sites More sharing options...
western Posted December 6, 2011 Share Posted December 6, 2011 I replaced my 110's Gemmer 6 bolt with a Adwest 4 bolt box, pipes fitted straight in with new 'O' ring seals, drop arm has to be changed to the 4 boly version as well. Quote Link to comment Share on other sites More sharing options...
smokinv8 Posted December 6, 2011 Author Share Posted December 6, 2011 Thanks OF, Ive only had one small bottle of beer too! Neil Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted December 6, 2011 Share Posted December 6, 2011 First off, the Disco only ever had a 4 bolt box. The drop arms from the disco and defender 4 bolt units are compatible. Your best bet would be to "upgrade" your 6 bolt unit to a later 4 bolt one. They are pretty cheap 2nd hand and once you have one you can do a recon exchange for reasonable money if it turns out to be a bad one. Quote Link to comment Share on other sites More sharing options...
smokinv8 Posted December 7, 2011 Author Share Posted December 7, 2011 Thanks guys, il make a couple of calls and source a 2nd hand disco unit then. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted December 7, 2011 Share Posted December 7, 2011 Letg me know if you get stuck as I may have one here and I may be able to get it to Swindon just after Xmas if you are in no rush. Quote Link to comment Share on other sites More sharing options...
smokinv8 Posted December 7, 2011 Author Share Posted December 7, 2011 Ok mate I will. Should have some local mates with spares but if I struggle il pm you. Cheers Neil Quote Link to comment Share on other sites More sharing options...
