eds Posted December 29, 2011 Share Posted December 29, 2011 According to JCB this blue HP grease is not suitable for wheel bearings. I have just done all my bearings with this! Could it be too thick and sticky? Does anyone have a view? Should I worry? Has anyone else used it for wheel bearings and been confident it is ok? Quote Link to comment Share on other sites More sharing options...
pinny Posted December 29, 2011 Share Posted December 29, 2011 ive always used this blue grease but i think the reason for it not being recommended as it has a tendency to set and will bind but i have it in my bearings uj and anywhere else i can put grease chris Quote Link to comment Share on other sites More sharing options...
tacr2man Posted December 29, 2011 Share Posted December 29, 2011 Sounds like you should have read the spec before you used it , if the seller says its not suitable I would be pretty sure it isnt , start again Quote Link to comment Share on other sites More sharing options...
pinny Posted December 29, 2011 Share Posted December 29, 2011 i think the other grease jcb do is epl which is brown if i remember corectly but ive always used the blue and i think a lot of othere do chris Quote Link to comment Share on other sites More sharing options...
Frax Posted December 29, 2011 Share Posted December 29, 2011 Any grease is better than none. Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted December 29, 2011 Share Posted December 29, 2011 I used some on my racer which uses Land Rover bearings/stubs/hubs. I put standard grease one side, blue the other about a year ago. I stripped both corners earlier this week and compared. There was little discernible difference between the two, possible the blue grease had held to the bearings better but not a startling difference. Don't lose any sleep over it. Quote Link to comment Share on other sites More sharing options...
rick Posted December 30, 2011 Share Posted December 30, 2011 What are the specs ? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted December 30, 2011 Share Posted December 30, 2011 I've pretty-much always used JCB blue grease when fitting wheel bearings and have done so for years. I've never once had a problem with using it. Les. Quote Link to comment Share on other sites More sharing options...
eds Posted December 30, 2011 Author Share Posted December 30, 2011 HP Grease Colour: Blue Soap Type: Lithium Complex NLGI: 2 Drop Point (IP132): 245°C Working Temperature Range: -20°C to 150°C Part number: 4003/2017 Size available: 400g tube (box of 24) Quote Link to comment Share on other sites More sharing options...
rick Posted December 31, 2011 Share Posted December 31, 2011 With those specs it should be fine for average use. Quote Link to comment Share on other sites More sharing options...
Jack Sugden Posted December 31, 2011 Share Posted December 31, 2011 I've just bought some Lucas grease that is blue, not sure if the specs are the same as the JCB stuff off hand but it seems to do the job ok. http://www.ebay.co.uk/itm/320757986158?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2648#ht_500wt_1180 Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted January 2, 2012 Share Posted January 2, 2012 "Soap Type: Lithium Complex" its the same stuff as Rocol Sapphire thats also blue-the only problem I find is that it hardens/sets when extruded or pushed out of bearings, saying that I use it in the main bearings on our massive extraction plant that runs at high speeds with huge loadings and never have any problems with the bearings. Should be fine in LR bearings. Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted January 3, 2012 Share Posted January 3, 2012 i worked for a plant hire company running upwards of 1000 jcb telehandlers,the blue grease supplied by jcb is supposed to be non hardening,as it is used in all the pivot points,well thats if they bothered to drill the holes in the pivot points at the factory! Quote Link to comment Share on other sites More sharing options...
