stuck Posted January 2, 2012 Share Posted January 2, 2012 Gents, On my 2000 defender the fog lights haven't worked since my engine change. On the drawing it shows the switch in series with "ECU-lamp-fog guard-rear" is this referring to the engine ECU that I no longer have? Cheers. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 2, 2012 Share Posted January 2, 2012 No It's a relay, stuck. It'll be in the fusebox or behind the dash, I can't remember which ! Hth Mo Quote Link to comment Share on other sites More sharing options...
stuck Posted January 2, 2012 Author Share Posted January 2, 2012 Mo, Thanks for the reply but I don't think it is a relay, or if it is it isn't depicted as one on the drawing. Rather than the relay symbol it just shows a blank square with the above text over it. Buggered if I know what it is or where it's located. Mick. Quote Link to comment Share on other sites More sharing options...
Buzza Posted January 2, 2012 Share Posted January 2, 2012 There is a 'Fog Lamp ECU' behind the instrument panel on an '02 model, between the steering column bracket and demist vent. Prob the same as yours. Steve Quote Link to comment Share on other sites More sharing options...
stuck Posted January 2, 2012 Author Share Posted January 2, 2012 Cheers Steve, Found it. If anybody else reads this looking for the same unit the part number is YWC104430. Mick. Quote Link to comment Share on other sites More sharing options...
western Posted January 2, 2012 Share Posted January 2, 2012 it looks like this http://www.numcat.ru/landrover/p/31/52853/ Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 2, 2012 Share Posted January 2, 2012 It is a sort of a relay Mo Quote Link to comment Share on other sites More sharing options...
