buddelflink Posted January 3, 2012 Share Posted January 3, 2012 Hallo, had someone more information, especially registration document, about this trailer? Thanks. Regards Rene Quote Link to comment Share on other sites More sharing options...
plasticbadger Posted January 6, 2012 Share Posted January 6, 2012 I know it's a 1 3/4 ton Arrows trailer, ex-UK MOD. http://www.mod-sales.com/auction/vehicle/related/38543/1.34_Ton_Trailer_Arrows_EX_Military.htm Quote Link to comment Share on other sites More sharing options...
western Posted January 6, 2012 Share Posted January 6, 2012 Normall towed by the 4 tonne Bedford MK/MJ or Leyladn DAF 4x4 trucks, Army reckon it's to wide to Tow behind a 90 or 110. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted January 6, 2012 Share Posted January 6, 2012 The pintle height and ring dia will be a tad large for the dixon bate hitch on a 90/110. Often see that size trailer with genny's on 15-25KvA behind a 4 tonner Quote Link to comment Share on other sites More sharing options...
buddelflink Posted January 7, 2012 Author Share Posted January 7, 2012 Thanks. The manufacterer is Parotow Ltd. At this time I use the trailer behind a LR 110 V8. It works fine, but the LR-hook is ca. 20cm to deep and therefore the trailer is a little bit angular. Had anybody a manual or more technical informations? Regards Quote Link to comment Share on other sites More sharing options...
jai_landrover Posted January 7, 2012 Share Posted January 7, 2012 I towed one back from a farm in Northampton behind my 90 on a std nato hitch. Trailer is quite wide. I ended up getting rid of the trailer but still have 2x wheels and tyres. I think they are 825 R16 wheel nuts are like bedfords LH and RH threads. Jai Quote Link to comment Share on other sites More sharing options...
western Posted January 7, 2012 Share Posted January 7, 2012 The pintle height and ring dia will be a tad large for the dixon bate hitch on a 90/110. Often see that size trailer with genny's on 15-25KvA behind a 4 tonner NATO tow ring is 76mm standard, Quote Link to comment Share on other sites More sharing options...
Guest Posted January 7, 2012 Share Posted January 7, 2012 If it's for a Land Rover you would be better with a rapier trailer as it has the same PCD as a Land Rover they are also slighty narrower than the Arrows trailer above. Jason. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 8, 2012 Share Posted January 8, 2012 NATO tow ring is 76mm standard, I thought the ones like that for going behind the Bedfords had a larger hitch? or am I wrong? Quote Link to comment Share on other sites More sharing options...
western Posted January 8, 2012 Share Posted January 8, 2012 5 ton [LR] nato pintle http://www.dixonbate.co.uk/towing/product.asp?PartNo=FV987958 Suitable for towing eyes: I.D. 75.00 mm. Section thickness: 38 or 41 mm 7 ton 4 tonne truck nato pintle http://www.dixonbate.co.uk/towing/product.asp?PartNo=FV987957 Suitable for towing eyes: I.D. 75.00 mm. Section thickness: 38 or 41 mm as you can see the tow ring is still the nato standard. Quote Link to comment Share on other sites More sharing options...
jai_landrover Posted January 8, 2012 Share Posted January 8, 2012 Twas a struggle towing one of them back from Cambridge on 900 XL's a disco Transfer box and 3.5 diffs!! Ow did I mention they're quite wide. Follwing the white line with one tyre. on the country lanes I had to becareful not to get the trailer nearside wheel in the grass verg when people were coming past me. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 8, 2012 Share Posted January 8, 2012 5 ton [LR] nato pintle http://www.dixonbate...PartNo=FV987958 Suitable for towing eyes: I.D. 75.00 mm. Section thickness: 38 or 41 mm 7 ton 4 tonne truck nato pintle http://www.dixonbate...PartNo=FV987957 Suitable for towing eyes: I.D. 75.00 mm. Section thickness: 38 or 41 mm as you can see the tow ring is still the nato standard. Thanks for that Ralph, learn something every day Quote Link to comment Share on other sites More sharing options...
pete3000 Posted January 10, 2012 Share Posted January 10, 2012 must be an optical illusion thing. I was convinced there were two different sizes (for different weights). I know for sure the commercial 2 tonne ring hitch is smaller dia and cross section? Quote Link to comment Share on other sites More sharing options...
western Posted January 10, 2012 Share Posted January 10, 2012 Civvy ring hitch is 32mm IIRC, there is a bigger nato pintle which has a bolt fixing to rear of a HGV chassis, IIRC these are 10tonne or 35tonne, the D.R.O.P.S. Foden's & Scammels's 8X6 trucks would have these. Quote Link to comment Share on other sites More sharing options...
