Baz2236 Posted January 9, 2012 Share Posted January 9, 2012 Hi I have a 200 TDI Engine in my 90 but having trouble getting the correct power steering / fan belt. The setup is the same as this one not my pic my is much more dirty. I order a fan belt for a 200 Disco and got a 13mm wide and 1025 legth but this is too small I then used a 11A1025C but this slipped and not had much adjustment so now I have a 10mm 1014 which is a QBA1014. This also slips As the recommeded one is a 13mm width I am guessing it would not slip as much as the thinner ones i have been using. But what size should I be running as the 1025C is too small. has anyone got an suggestions what belt to try next. Baz Quote Link to comment Share on other sites More sharing options...
19MART82 Posted January 9, 2012 Share Posted January 9, 2012 discovery or defender engine?ive just fitted a new power steering pump belt on my 200tdi defender engine,the part no. is ETC5815 and it fits perfect,not sure if the 200tdi discovery belt is the same? im not sure of the fan belt part no. sorry Quote Link to comment Share on other sites More sharing options...
Baz2236 Posted January 9, 2012 Author Share Posted January 9, 2012 Its a Discovery Engine Quote Link to comment Share on other sites More sharing options...
19MART82 Posted January 9, 2012 Share Posted January 9, 2012 picture didnt show up when i first looked,different setup to defender engine sorry cant help Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted January 10, 2012 Share Posted January 10, 2012 Cant help with lengths but the belt that goes from crank to water pump and then pas pump should be 13mm wide, anything smaller will fall into the gap and not grip the Vee's. Every landy specialist accross the land should be able to sell you a belt for about £3. Quote Link to comment Share on other sites More sharing options...
Ratty43 Posted January 10, 2012 Share Posted January 10, 2012 Halfords is very useful for sorting out belts as you can keep on swapping them until you get the right one. That said I can't see why you should be having problems since that is the standard set up. Quote Link to comment Share on other sites More sharing options...
Baz2236 Posted January 11, 2012 Author Share Posted January 11, 2012 That's what I thought it's standard be easy to get a belt I have got another landie one on the way hopefully it be the right one. But I not holding out much hope. Quote Link to comment Share on other sites More sharing options...
