dicsosfa Posted January 16, 2012 Share Posted January 16, 2012 hi looking for some advice want to carpet the inside rear load space,seatbox and bulkhead but unsure do i glue direct onto metal or onto plywood ? have seen a lot of gel backed auto carpet but its a bit costly dont really want to use house hold carpet i.e. foam or rubber backed. can i use flotex kitchen carpet what adhesive can i use for sticking carpet to metal or wood ? any help or advice welcome Roy. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted January 16, 2012 Share Posted January 16, 2012 Look no further than http://www.megavanmats.com/. I used them when converting my van to a camper. They supply proper high temperature adhesive (so the carpet will not fall off once the sun shines onto your car!) and proper unbacked lining carpet which will stretch around contours - OK, I know there are not many contours in a LR but think about the filler box and the rear lamp covers. You should be able to do a really nice job with the right materials. HTH Chris Quote Link to comment Share on other sites More sharing options...
