Bellhousings
This might help ----- Bell housings
Gearbox serial number need for this [the 1st 3 digits at least]
LT77 --- all upto chassis number LA939975
50A -- FRC9865 ------- now corrected :rolleyes:
56A as above
60A -- FRC6154
61A as above
V8/R380
FTC3922
300Tdi/R380
FTC3921
200Tdi/R380 use FTC4018 a 'stumpy' 11cm overall length bellhousing, apparently not the 14cm LT77 variant that I originally thought.
all the above are for Defender
these for Discovery upto chassis number LA081991
V8/LT77S---------------- FRC6154
200Tdi/LT77S ----------- FTC1270
300Tdi/R380 ------------ FTC3921
V8 carb./R380 ---------- FTC3922 --- superseded by UNB100190
V8 efi/R380 ------------- FTC3922 --- as above.
these for Range Rover from chassis number starting CA to HA610293
VM diesl/LT77 ----- FRC8570
V8/LT77 ------------ FTC6154
these for Range Rover from chassis number JA610294
200Tdi/LT77 -------- FTC1270
V8/LT77 ------------- FTC6154
VM diesel/LT77 ----- FTC8570
300Tdi/R380 -------- FTC3921
V8/R380 ------------ FTC3922 ---- note supersession as per Discovery list above.
:i-m_so_happy:
Edited by western
amended.
Well my R380 bolted straight to mine [200Tdi with FTC4018 ] OK & a LR main dealer did the orignal R380 fit, they didn't have any problem,IIRC the R380 to V8 has a different mainshaft,
where's Dave Ashcroft when you need him :ph34r::unsure:
Edited by western
Well my R380 bolted straight to mine [200Tdi with FRC9865] OK & a LR main dealer did the orignal R380 fit, they didn't have any problem,IIRC the R380 to V8 has a different mainshaft,
Well yes erm... Mr Ashcoft told be i'd need a new bellhousing, i was just seeking a second opinoin as it seemed strange as i thought the r380 was the same fitting pattern as the LT77
I'm not actually any wiser at the mo. Anyone know for certain?
YES I have experienced this...
The R380 is slightly longer (~25mm) than the LT77, so with the V8 for reasons unknown they made the bellhousing ~25mm shorter. You can physically bolt one to the other, but the input shaft will end up 25mm too long or too short :( and that's a major PITFA.
I ended up buying a bellhousing from Mr Ashcroft as it was just easier and quicker than trying to find a correct one elsewhere - seems most of the LR "experts" don't realise the difference either and several tried to sell me LT77 versions :angry:
Oh and in case this should end up in the tech archive - the tail housings that contain the gearshift are completely different internally between Defender and Disco/RR so you can't swap the shift mechanism over - ask me (and Marco Cosic) how we know <_<
Oh, just found a nice piccy of my R380 - this is the correct bellhousing and a Defender shift mechanism (comes forward from the tail housing):
This is the RR/Disco shifter tail housing (viewed from above looking in):
This is the Defender tail housing (viewed from above looking in):
  • 1 month later...
anyone know if a rangerover 3.5 v8 4speed auto box would bolt onto a disco 200tdi engine if it doesnt can i just swap the bellhousings over and would the output shaft be the same length and diameter
cheers
EPC tells me the RRC 4 speed auto torque convertor housing is RTC6594 on V8 vehicles which is the same on Discovery 1 4 speed auto & V8 vehicles, but the housing on a 200Tdi Discovery 1 auto is STC1581, the parts drawing doesn't give enough picture detail to determine the differences, probably have to have one of each housing side by side to tell, hope that helps.
i'm slightly confused still
clarified on a v8 the parts are not interchangeable.
but for 4 pot...
FRC9865 fits on end of lt77 and also fits on the end of r380. does this overcome the 25mm length problem in this application regarding the input shaft?
also, regarding this stumpy bellhousing, surely the input shaft would be way too long, given the difference in bellhousing length between r380 and 4 pot lt77, were you to attach frc9865 to an r380.
am i getting horribly mixed up?
but for 4 pot...
Some R380 have a short mainshaft for different applications, like my own R380 which has the 'stumpy' bell housing & bolted to my Defender spec 200Tdi.
the 300Tdi engines sit further forward in the engine bay & have a longer mainshaft & longer bell housing.
Edited by western
ahh i see, two different r380's then, normal and short, the latter i presume being somewhat rare.
Edited by western
  • 1 year later...
anyone knows if an sd1 V8 lt77 can be adapted to fit in landrover 90? would the engine foul the bulkhead or no?
Luwts
I asked this question a couple of years ago - apparently you cannot mate the box to the LT230 in any way.
  • 10 months later...
