LandyManLuke Posted February 5, 2012 Share Posted February 5, 2012 Hi all, I'm doing some research in to using a standard LT230 speed transducer with a non-LR dash. Does anyone know if the standard sensor is hall effect, pulse etc, and what the pin connections are? Thanks, Luke Quote Link to comment Share on other sites More sharing options...
western Posted February 5, 2012 Share Posted February 5, 2012 pin ident is 1 = 12v feed 2 = earth 3 = signal from transducer to speedo all viewed from the pin ends that go into the transducer with pin1 to the parent vehicle front/main gearbox also see the left sheet of the attachments on post 221 http://forums.lr4x4.com/index.php?showtopic=14892&st=220] in the wibbly wobbly speedo thread[/url] Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 5, 2012 Share Posted February 5, 2012 You can see the guts of a transducer in this thread http://forums.lr4x4.com/index.php?showtopic=70254 It seems to be a spinning magnet. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted February 5, 2012 Author Share Posted February 5, 2012 Thanks for the link. I'm guessing its actually a hall effect sensor, rather than a reed switch as indicated in that post, given the speeds it has to work at. Pulse count isn't a problem, as the dash it's going on is configurable. Quote Link to comment Share on other sites More sharing options...
knacker Posted February 5, 2012 Share Posted February 5, 2012 Hi all, I'm doing some research in to using a standard LT230 speed transducer with a non-LR dash. Does anyone know if the standard sensor is hall effect, pulse etc, and what the pin connections are? Thanks Luke Wonder where you got that idea ? Rich's ears picked up when I mentioned using one of them to him earlier. Jon Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted February 5, 2012 Share Posted February 5, 2012 When testing TD5 Defender Speedos I use a 66.6Hz 12v p-p square wave dc biased so there is no negative voltage. This indicates at 60mph on a speedo. Quote Link to comment Share on other sites More sharing options...
