Frax Posted February 8, 2012 Author Share Posted February 8, 2012 I must have posted at the same time as you, Nice job there and it looks strong - will have to see what I have laying about here - thanks for the picture. Have pillar drill and welder so just need to see if I have some steel. Quote Link to comment Share on other sites More sharing options...
LRNZ Posted February 8, 2012 Share Posted February 8, 2012 I have a difflock locking bar, whilst it may not be the cheapest, I've used it to change many belts and I think its worth the money. Makes the job a breeze Get yourself the correct tool, or alternatively the whole kit, and you will be changing a timing belt in no time. cheers P Quote Link to comment Share on other sites More sharing options...
mmgemini Posted February 8, 2012 Share Posted February 8, 2012 Ric You have a lot more faith in a flywheel lock pin than I have.....I bent mine and I didn't try anything like using it to hold the engine.A ring spanner and a hammer does me. Quote Link to comment Share on other sites More sharing options...
Mutley Posted February 8, 2012 Share Posted February 8, 2012 Bloke on Bay of E makes them, got one myself very impressed and the guy is very helpful too If you put in best offer he'll do it for £50 comes painted too... the guys user name is blueloctiteman Quote Link to comment Share on other sites More sharing options...
will4x4 Posted February 8, 2012 Share Posted February 8, 2012 when i tightened mine up i just stuck loads of lock tight on it and used an air gun. its held so far. Quote Link to comment Share on other sites More sharing options...
danebrewer Posted February 27, 2012 Share Posted February 27, 2012 I made one- just a couple of pieces of flat bar filed out to go round the curvature of the crank shaft, welded to a piece of strong tube, which I bolted to the TV damper and braced against the chassis rail, you can then unbolt it and fit thecrank pulley over the crank nut Quote Link to comment Share on other sites More sharing options...
dantd5 Posted February 27, 2012 Share Posted February 27, 2012 This is my tool..... SAved loads of quids.... Quote Link to comment Share on other sites More sharing options...
dantd5 Posted February 27, 2012 Share Posted February 27, 2012 more pics Quote Link to comment Share on other sites More sharing options...
dantd5 Posted February 27, 2012 Share Posted February 27, 2012 and this.. (most likely a mod will help out with this) An L shaped metal from the scrap yard. Took measurement and drilled 2 holes to match and vipsilabom.. I cranked the bolt. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted February 27, 2012 Share Posted February 27, 2012 more pics.. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted February 27, 2012 Share Posted February 27, 2012 The Bolt Quote Link to comment Share on other sites More sharing options...
Christophers1247 Posted February 28, 2012 Share Posted February 28, 2012 big impact gun and locktight will never move. Quote Link to comment Share on other sites More sharing options...
