axaazaqwe Posted February 11, 2012 Share Posted February 11, 2012 I did an earlier post with the same problem as the diagnosis of the garage was that all 4 injectors had gone, this was considered unusual on this forum and by others outside of it and I was recommended by others to visit a local fuel injection garage who fitted an inline fuel pump as to being the cause, 2 weeks later returned as same problem came back after a week, they then said it probably was the injectors and had it for a couple of days after which they said it wasnt the injectors,will be booking it into a landrover garage soon but in addition to the stalling a couple of times the hill descent light has come on the dash and the engine will not fire for a couple of minutes after stalling, any connection, and anyone got any ideas what it is Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 12, 2012 Share Posted February 12, 2012 Is it *just* the HDC light or is it the "three amigos" (HDC, ABS, TC)? Sounds like an electrical fault to me. Quote Link to comment Share on other sites More sharing options...
axaazaqwe Posted February 12, 2012 Author Share Posted February 12, 2012 Funningly enough those three lights came on today on one of the stalls but not on any of the other stalling today, might have been all three before but last time I noticed the HDC light I was on my way to catch a plane and was more concerned about getting there, just another thing I have noticed which may have no connection at all is that it seems to stall and hesitate more in Drive than in 4th and have noticed that when you put it into Sport mode the display doesnt alter on the dash just stays on D, but I could be clutching at straws there. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 12, 2012 Share Posted February 12, 2012 It sounds almost like it's accidentally going into HDC mode (which would cut the power right down and try to go at walking pace) or something like that. Quote Link to comment Share on other sites More sharing options...
Phil Wilson Posted February 17, 2012 Share Posted February 17, 2012 I recently had a similar problem to this, which eventually I found to be a dry joint on the injector harness. It was intermittent because whenever I took the inlet manifold off as I was poking around, I would disturb the harness and make it connect again for a bit. Reving the engine would make the whole unit twist on it's mounts, and sometimes cause the bad connection. Have you connected a diagnostics and found any fault codes? If garages think it is the injectors, did they find a code, and have they tried swapping the injectors around to see if the fault follows the injector or not (i.e. injector or harness)? Quote Link to comment Share on other sites More sharing options...
axaazaqwe Posted February 21, 2012 Author Share Posted February 21, 2012 Problem sorted, took it to a proper garage, someone who knows landrovers, Cyril Groombridge in Heathfield East Sussex, problem found within 5 mins, regulator and wiring loom, both replaced, running sweet now, thanks for everyones input, none of you wide of the mark. 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 22, 2012 Share Posted February 22, 2012 For future generations, which regulator / wiring loom was it? Quote Link to comment Share on other sites More sharing options...
Lill james Posted May 27, 2021 Share Posted May 27, 2021 Hi i have a freelander 2 11 plate she sometimes stalls when you go to take of have to rev her to keep her going any idea thanks Quote Link to comment Share on other sites More sharing options...
