robbie1717 Posted March 19, 2012 Share Posted March 19, 2012 Hi I fitted a EGR Valve Removal Kit, now i want to tidy it all up a bit by fitting a Vacuum Hose without the EGR "T" in it. Can anyone help by giving me the part number for a "non EGR" Brake Vacuum Hose to fit: Defender Td5 Year: 2003 Right Hand Drive No ABS Cheers Robbie Quote Link to comment Share on other sites More sharing options...
western Posted March 19, 2012 Share Posted March 19, 2012 just buy a length of suitable hose from your local motor factor, it'll be just as good as the genuine LR hose & most likely a whole lot cheaper. Quote Link to comment Share on other sites More sharing options...
robbie1717 Posted March 23, 2012 Author Share Posted March 23, 2012 You mean Vacuum Hose right? Or just any Fuel/Oil Hose??? Quote Link to comment Share on other sites More sharing options...
western Posted March 23, 2012 Share Posted March 23, 2012 any hose will do the job, there's nothing special about the hose. Quote Link to comment Share on other sites More sharing options...
robbie1717 Posted March 24, 2012 Author Share Posted March 24, 2012 OK Cheers. Having had a look at the original though, i wonder if its possible to just remove the "T" Connector where the EGR System used to get Vacuum from and replace it with a straight through Connector? Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2012 Share Posted March 24, 2012 that should work OK. Quote Link to comment Share on other sites More sharing options...
