Smithy155 Posted March 25, 2012 Share Posted March 25, 2012 Hi all, I'm removing the injection pump off of my Defender 200tdi tomorrow and i've never done it before. So to save a lot of work i was wondering, can i remove the pump by only taking off the small inspection plate on the timing cover? Or do i have to do it the long way around by removing the whole timing cover and everything else that goes along with it? Quote Link to comment Share on other sites More sharing options...
western Posted March 25, 2012 Share Posted March 25, 2012 if you have the timing gear holding tool, the pump can be removed without stripping the timing case front cover & water pump off, then it's the 3 small bolts on the timing gear & the 3 nuts securing the pump to rear face of timing case & the pipes to injectors & elcet wire to shutoff unit when was the timing belt changed ? if unknown now would be a good time to do that job as well. & then you can get the timing set up correct. wouldn't attempt these jobs without a timing tool kit like this one mine came from ebay, just a good. Quote Link to comment Share on other sites More sharing options...
Smithy155 Posted March 25, 2012 Author Share Posted March 25, 2012 Thanks for the reply! I changed the timing belt last year at about this time hence why i don't really want to take everything apart again if i don't have to. I'm guessing that timing kit simply has a few bolts that screw into the pulley and hold it within the inspection hole so it doesn't fall down in to the timing case? ... if it's as simple as that i could easily manufacture something myself of the same function, or am i missing something? Quote Link to comment Share on other sites More sharing options...
western Posted March 25, 2012 Share Posted March 25, 2012 OK with the recent timing belt change. Yes, the FIP gear retainer holds the gear & timing belt tension so the FIP can be removed, fits as shown on the atached workshop book pages Quote Link to comment Share on other sites More sharing options...
Smithy155 Posted March 25, 2012 Author Share Posted March 25, 2012 Wonderful job thanks for your help! Just out of curiosity what defender manual are those attached pictures from? i've been searching through the manuals i have and have found nothing similar. Quote Link to comment Share on other sites More sharing options...
western Posted March 25, 2012 Share Posted March 25, 2012 from the genuine manual part LDAWMEN93 1993 includes 200tdi but not 300tdi engine. you can read it here -- http://www.retroanaconda.com/landrover/category/resources/ Quote Link to comment Share on other sites More sharing options...
