smithy1 Posted March 28, 2012 Share Posted March 28, 2012 My inside roof light doesnt work when u open the doors but works when u turn it on manualy any body know out about these? Cheers smithy Quote Link to comment Share on other sites More sharing options...
Disco DJ Posted March 30, 2012 Share Posted March 30, 2012 That would indicate the door switch then, wouldn't it? Is it all/any doors or just driver's door? Dave Quote Link to comment Share on other sites More sharing options...
sierrafery Posted April 1, 2012 Share Posted April 1, 2012 My inside roof light doesnt work when u open the doors but works when u turn it on manualy any body know out about these? Cheers smithy all of them or just the front one? ... it's important to know cos they are managed by the BCU a door switch would have disturbed the alarm too...and the SLS if fitted Quote Link to comment Share on other sites More sharing options...
smithy1 Posted April 3, 2012 Author Share Posted April 3, 2012 its all of the doors ive replaced the unit in l/h front door due to it wouldnt lock or unlock thats ok now but still no inside lights or locking on the key fob Quote Link to comment Share on other sites More sharing options...
smithy1 Posted April 3, 2012 Author Share Posted April 3, 2012 sorry alarm works but not on the key fob no beeps when locking also whats SLS ? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 4, 2012 Share Posted April 4, 2012 self levelling suspension Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted April 4, 2012 Share Posted April 4, 2012 Mine did this the other day. And next time I tried it after a short drive it worked again! No idea what the problem is though sorry Quote Link to comment Share on other sites More sharing options...
sierrafery Posted April 4, 2012 Share Posted April 4, 2012 The interior courtesy lamps are timed... if a door was opened a longer time then closed without turning ignition the lamps will not work. Do they work when you turn ignition off? ...if yes check again after locking/unlocking doors...if not, and taking into account the alarm/fob missbehaviour too check for water ingress at the BCU's plugs and u can try to join together the purple/blue trace wires from highligted plug in the pic.... water ingress from the windscreen is causing corrosion in the plugs there The BCU is not far from this plug on the same post but u have to remove the glovebox to reach it Quote Link to comment Share on other sites More sharing options...
smithy1 Posted April 4, 2012 Author Share Posted April 4, 2012 great post cheers i check this tomorrow , but the lights dont work at all unless u turn the switch to on ???? but not with opening the doors or after locking or unlocking it has the normal problem of blocked sunroof tubes Quote Link to comment Share on other sites More sharing options...
smithy1 Posted April 8, 2012 Author Share Posted April 8, 2012 fixxxxxxed !!!!!!!!!!!!!!!!!!!!!! more than happppy !!!!!! thanks sierrafery for the great replys this was spot on also great use of pics ! after fixed i had too start and stop and open and lock the disco a few times then spot on cheers everybody for the replys but now the nexted problem.... central locking doesn't work ,anybody no why it doesnt lock with the key fob fobs been tested and check out ok all door lock with the key in the lock but not with the buttons on the key could this be a quick fix too Quote Link to comment Share on other sites More sharing options...
wildeone2 Posted September 30, 2014 Share Posted September 30, 2014 fixed my interior lights as well connector is well corroded is it safe to bypass the other 3 wires on the block of 4 at end of connector or are they common joined within connector Quote Link to comment Share on other sites More sharing options...
wildeone2 Posted September 30, 2014 Share Posted September 30, 2014 forgot to say thanks to sierrafery for this sorry Quote Link to comment Share on other sites More sharing options...
Robl88 Posted March 22, 2017 Share Posted March 22, 2017 What is the plug number for this connector? I have the same problem with my interior lights. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted March 23, 2017 Share Posted March 23, 2017 C0484/0102 purple/blue wire Quote Link to comment Share on other sites More sharing options...
Davej25 Posted April 4, 2021 Share Posted April 4, 2021 On 4/4/2012 at 2:29 PM, sierrafery said: The interior courtesy lamps are timed... if a door was opened a longer time then closed without turning ignition the lamps will not work. Do they work when you turn ignition off? ...if yes check again after locking/unlocking doors...if not, and taking into account the alarm/fob missbehaviour too check for water ingress at the BCU's plugs and u can try to join together the purple/blue trace wires from highligted plug in the pic.... water ingress from the windscreen is causing corrosion in the plugs there The BCU is not far from this plug on the same post but u have to remove the glovebox to reach it Would this be the problem that my air suspension not working! my lights work when turned on but will not work when doors open! Any help would be good ? Quote Link to comment Share on other sites More sharing options...
sierrafery Posted April 5, 2021 Share Posted April 5, 2021 They can be related only if the fault is caused by the door switch circuit cos if the input to the BCU is like the door is open the compressor is disabled too Quote Link to comment Share on other sites More sharing options...
Davej25 Posted May 3, 2021 Share Posted May 3, 2021 Sierrafery thank you I manage to get SLS to work the compressor had packed up and was blowing the fuse under hood what else should I look at for interior lights they still do not come on when you open doors they do when you switch them on?? Alarm sets and goes off if set off and all doors lock with key fob. Quote Link to comment Share on other sites More sharing options...
sierrafery Posted May 4, 2021 Share Posted May 4, 2021 check what's in post 21 Quote Link to comment Share on other sites More sharing options...
