High Pitch Noise
Jamest535
Could be (but not limited to) split in the intercooler, a split in a different hose, turbo hose collapsed internally, blocked air filter, chipped turbo impeller, cracked manifold.... the list goes on :)
What sort of noise, a whistle, a sort of whooshing compressed air noise, a whine, or what? Are there any other symptoms e.g. loss of power?
mine had a very high pitched whistle, turned out to be a slight split in the vacuum hose connected to the brake servo. the smaller hose on the 'T' connector located above the servo. don't know what it does but everything worked OK!, quieter now though!
gary
Gary
If I rememebr correctly you can get to all of the heater stuff if you drop the passenger glove box. The heater motor is in the passenger footwelll and its only 3 bolts to take it out.
HTH
Ivan
