Fatboy Posted August 22, 2006 Share Posted August 22, 2006 Hi, A few months ago I when I replaced the plugs in the V8, they were a swine to remove and indeed I stripped the threads on the block with one of them. They seemed to be corroded around the bottom of the threads... Last night, I replaced the plugs on the other V8 and they were not as bad although going the same way.. Both engines are 3.5's, running on carbs with BP6RES Plugs and LPG. I'd appreciate any thoughts ? Quote Link to comment Share on other sites More sharing options...
jiginc Posted August 22, 2006 Share Posted August 22, 2006 Never had a problem on my 3.9. I always use copper grease. If you don’t give it a try. JIGINC Quote Link to comment Share on other sites More sharing options...
Fatboy Posted August 22, 2006 Author Share Posted August 22, 2006 I had it on the gas tester today and it was way out... was running lean at high revs (=all the time when SWBO at the helm). Hopefully all it did was the plugs and not the valves etc. Its running okay now, much smoother Quote Link to comment Share on other sites More sharing options...
