1" drive breaker bar - NO JOINTS.
Astro_Al
The torque required to break out a component cannot be used to calculate make-up torque. Especially if the component has been done up for a while.... :ph34r:
My opinion, (for what it is worth), if you can get good access to nut, I'd consider using either a hydraulic spanner (Hytorq or such like) or hammer spanners which even if you do not beat them, are easier to put a cheater bar on. An advantage being that you are applying force through the same plane as the nut, not a couple of inches in front which introduces bending loads.
Hytorq tools can be rented as well.... no need to purchase. ;)
Hmm, somewhere in between 15 and 8 stone is where I weigh in... <_<
Hanging Moglite from the end of the bar with perfect his combination of space-time bending gravitational forces and attraction to all things rubber (placed on the ground beneath him), plus some :angry: angry :angry: ginger related pulling should be all the dynamic load I need...
If not, my fast'n'loud swearing at him will tip the balance in our favour, I'm sure. :P
Fatboy - You're right about the bending loads, but as I said above, I'll be welding it all up so the reverse side of the socket is also supported (by an axle stand or whatever), resulting in pure torsion at the socket (and hopefully a bit of stability at the angry end of the bar).
Cheers, Al.
Not sure on the safety side of my suggestion, but I have always found that applying both static and shock loading more effective than just shock loading to undo tight stuff...
ie In your setup Al, I would be inclined to do something like attach the bar to the nut, and then a big ratchet strap between the other end ans something good and solid. Do the rat. strap up so it is applying a good static load to the bar, and then apply a shock load (ie jump on it, hit it with a BFH, open the speacialist magazine... etc).
Mark
You have a hammer the same size as a Mog? I think that would count as a BFH.. :P
Also if Andy jiggling generates that much force, remind me to be in another county when you do this!!! :D
Alternatly, make him sneeze - this always seems to generate a lot of force when it happens under a vehicle... the bridge of my nose will testify to this!
Mark
I guess today is pick on me day :o
But I don't care - I drove MogLite last night for the first time last night - so nothing is gonna get me down today.
For the record - I'm about 14st, 6' tall and gorgeous - rather be that than 8st dripping wet carrying a bag of shopping :D
Rather than a massive breaker bar - use a trolley jack as force ?
Keeping the tool square on the nut can be a pain.
Shut your hole dough-boy! :P
Don't blame me, blame Isaac Newton and 'yo momma'... :D
WAHOO! :)
Yes you are Andy, yes you are. :)
Just pulling yo portal box me old mukka! ;)
Yeah, hence the jig, which will also keep it pushed 'on'. Got a drum going spare...? One of those smaller ones that wouldn't fit the brakes in? I can give you another 2 once I get the other front.
Al.
well strangely enough stick man its a wrench/spanner and you slug it/beat the living sh*te out of it with a rubber princess powered sledgie :lol:
looks a bit like this
or for kinky applications (stop sniggering in the back Marshalsay)
local tool monkeys should be able to help you out, single or Bi-hex, much thicker wall than any sockety things and the satisfaction of sledgehammer induced violence B)
Yeah, but at least we found out that there is life in the city today :hysterical: ………..and why is there no post in the Moglite thread telling us all the gory details :rtfm:
Well done Andy …… I expect you are are well chuffed :i-m_so_happy:
Ian
Ian
There is a little bit too much life in the City - I've been busy.
Its currently on 7.50s !! and no springs so it looks a little wierd
Grand unveiling is at Malvern on the Shires stand.
If you want a sneak preview - close your eyes and imagine a b**tard love child of a Tomcat and JCB Fastrac - paint it orange and black and you'll be darn close :D
Full LR4x4 updates after the weekend.
Andy AKA Rubber Princess :ph34r:
I was using the internationally harmonised constant for Swearing - Sfk = ((.707 x V) x Fn)
Sfk = Swearing coefficient
V = Volume
Fn = Nominal Frequency
Then:
Fn = (dW / Tr)
Tr = Time period in seconds between repetition of any given word
dW = Deviation of words utilised
A rapper would be a good choice for a high density of wearing, however their nomninal frequency (Fn) is actually relatively low as they tend to repeat the same few words in succession. Creativity is the name of the game, Andy is a bit of a deviant so his dW figure will be high :D
Edited to add: Rappers also suffer because they use the American measurement which includes "cuss" words such as "ass" which the international committee do not recognise, as such SAE Swearing is of lower value than DIN Swearing.
Fridge, thanks for your input - I've been giving the optimisation of the parameters some thought, so it doesn't take an entire weekend to crack 4 nuts...
Maybe you could help me out with a couple of newbie Q's:
1. If I need this truck to pass an SVA, and the international committee don't recognise US 'cuss' words, do I need to ensure that all swear words are DOT approved, or have the European equivalent 'E' mark? Also, should I record the event for future playback in case I need supply proof of recognised vocabulary during the SVA testing?
2. I'm trying to work out whether I'm shooting myself in the foot. I plan to hang a slugging wench off the bar, and beat it with my hammer (the bar that is - and the slugging wench maybe a little if his swearing quotient is sub-par). Given Moglite's remarkable 'standard gravitational parameter' (that is, his mass - yes, ALL of it - multiplied by the universal gravitational constant), and the considerable mass of my Mog-sized hammer, can you tell me whether the unfeasibly large local gravitational pull is going to slow my hammer down to such an extent that it becomes ineffective? Is there a 'critical hammer mass' at which point I would be better off just tickling the slugging wench to induce dynamic bar loads? Presumably a rubber 'tickling stick' produces greater vibration and dynamic loads?
3. Finally, if rappers are typically not up to the job given their limited and/or illegal vocabulary, considering the significant torque required to free a recalcitrant Mog hub bolt, can you suggest an alternative source of verbal abuse? Do HSS-Hire have anything I can rent by the hour? Most of their staff seem like they'd fit the bill?
Advice, or foot-pounds, gratefully received. Al. B)
I think the Zuess book carries all the relevant coversion tables for profanities.
Im a little concerned though Al as to your use of the rubber princesses ability to create a pocket of super gravity during mallet swinging - if you release the full force of rubberness then the batting stick could in theory surpass 2/3rds the speed of light and collapse under its own mass causing a black hole and sucking at least everyone elses axles into it (yours would of course be safe)
As I understant it they work on a points system using a conversion table in the book Jez was referring to. I won't reproduce it here as it's a family forum but for example:
1 SAE Ass = .6666 DIN Arses
Andy's standard gravitational parameter is somewhat of an unknown bignum as science is yet to quantify it accurately, or even begin to count the zeros :P
However, with careful computation of the arc of hammer travel (and you're the rocket scientist here) you should be able to use the gravitational pull to give a "slingshot" effect that accelerates the hammer toward the target.
Either that or the universe will implode - as per Jez's warning above.
Well, I realise this may be multitasking too far, but the rubber princess is reasonably adept at swearing and benefits from the aforementioned high level of deviance.
If that's asking too much I can record some local 12-year olds on tape - the dW is lower but the overall frequency is higher, especially when multiple urchins are employed.
News is filtering back that allowing "madam latex" to work on the Shires stand at Malvern could have a detrimental effect on new membership - why did you let him?.......... why??
Al you sure you want to let this loose with a sledgehammer??
still its an improvement on that colour co-ordinated affair he made initially
Biancas nice, Ive often admired her grinder fu although shes carp at repairing punctures
whereas.......
Kate Beckonlovely seems to have made herself at home in the lab - Im not sure she should be allowed to make anymore sidearms though, we're running out of shelves
just got an update from the show John
it seems Al's joined Andy on the "other side"
god help us
