landybehr Posted August 22, 2006 Share Posted August 22, 2006 Hi there, i wonder how to check the timing with the FORD EDIS-System firing the plugs. As that is a waste spark system it will give twice the number of sparks to the ignition lead as my stroboskope-timing light will expect. Does it matter / anything that could be done / how to proceed ????? Regards, Hendrik Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 23, 2006 Share Posted August 23, 2006 Hi there,i wonder how to check the timing with the FORD EDIS-System firing the plugs. As that is a waste spark system it will give twice the number of sparks to the ignition lead as my stroboskope-timing light will expect. Does it matter / anything that could be done / how to proceed ????? Regards, Hendrik Same as normal, connect strobe to No 1 lead and tweak Nige Quote Link to comment Share on other sites More sharing options...
