Prop-shaft flange problems
Morning 4X4
perhaps some one can help
I recently had to take the front prop-shaft off my vehicle & took it down to a local (specialist) for a replacement - who has gone into receivership with the shaft (hence i have no original)
Drive train configuration is as follows
R380 main box
LT230 Transfer box
both the boxes are from a Discovery I
Classic Range rover front axle
Have just ordered the prop-shaft part no out from paddocks FRC8386 which is a defender / discovery 1 compatible front prop-shaft I have found that the rear coupling is perfect size to fit the transfer box flange
Problem is the flange on the front axle is smaller than the flange on the front end of the prop-shaft
the defender flanges are of identical size its just the axle flange is smaller
anyone out there with any advice
1) is it possible to remove the smaller flange & put a larger (defender) flange on the front axle is so has anyone a part no
or
1) just buy a new prop-shaft with the defender (larger) flange & a smaller front flange a part no would really help
as delivery was to the continent it doesnt pay to ship the shaft back to the UK
appreciate any help
happy trails
Abe
Ser III Pick-up (def 90 re-build)
Classic RR Chassis & a Fern-intercooled 300tdi & K&N induction
