TheBeastie Posted June 11, 2012 Share Posted June 11, 2012 Hi Towbar electrics fubar and everything corroded shockingly (to be fair it is a lousy place to be down there on a permanent basis!!) so used angle grinder to get the nuts off the bracket that holds the 7 pin socket. Bracket itself not good but the socket I got with bracket attached no use for Defender since hole spacing too wide and holds the socket into the tie bar. Need original where hoe centres are about 60mm and the socket is held above the tie bar. Looked in the 110 parts manual but cannot find it. Anyone got any ideas what the number might be so I can get a new one? I suppose I might be able to make one but would prefer proper Thanks and best wishes Malcolm Quote Link to comment Share on other sites More sharing options...
mickeyw Posted June 11, 2012 Share Posted June 11, 2012 Couldn't you use something like this? You could just use it as intended to position the socket beside the ball, or modify it to use bolted to the side stays. Quote Link to comment Share on other sites More sharing options...
western Posted June 11, 2012 Share Posted June 11, 2012 got 2 of those on my 110, should be item 8 on page 1059 Accesories section in 110 1987 on parts book, http://www.retroanaconda.com/landrover/parts_books/110/10_trim_seats_stowage_accessories_p910-1075.pdf LR part NRC8048 Brt-car http://www.brit-car....php?xProd=88510 LR Series http://www.lrseries....TING-PLATE.html Famous four http://www.famousfou...p?partID=397191 Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted June 11, 2012 Author Share Posted June 11, 2012 Thanks Ralph. Never thought of Accessories - tried chassis and electrics. One lives and learns!! Quote Link to comment Share on other sites More sharing options...
western Posted June 11, 2012 Share Posted June 11, 2012 only just remembered where I found them in the parts book, Quote Link to comment Share on other sites More sharing options...
