Guest mr_wuffles Posted August 29, 2006 Share Posted August 29, 2006 What are the differences between a 110 300 tdi CSW and a 110 td5 CSW chassis? I can think of the rear crossmember and engine mounts. anything else? are the gearbox mounts in the same place? Quote Link to comment Share on other sites More sharing options...
white90 Posted August 29, 2006 Share Posted August 29, 2006 rear x member and a fitment for the fuel filter other than that there will probably be a few small brackets/clips to suit different wiring looms. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 29, 2006 Share Posted August 29, 2006 From crawling under my Td5 110 SW and (trying to remember) my old 300Tdi 110 SW, apart from the obvious like you mentioned (rear crossmember & engine mounts) i think they were the same. the gearbox mounts certainly look the same. shout if you want any pics/measurements of the Td5 one. Quote Link to comment Share on other sites More sharing options...
Guest mr_wuffles Posted August 29, 2006 Share Posted August 29, 2006 From crawling under my Td5 110 SW and (trying to remember) my old 300Tdi 110 SW, apart from the obvious like you mentioned (rear crossmember & engine mounts) i think they were the same.the gearbox mounts certainly look the same. shout if you want any pics/measurements of the Td5 one. Cheers i've bought a td5 110 double cab body and have a 110 CSW chassis from a 300 Tdi, i was going to get it galvanized and wanted to make sure before hand. I'll may come back To you for some measurements Jamie Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 30, 2006 Share Posted August 30, 2006 No probs mate. Quote Link to comment Share on other sites More sharing options...
