mcc1979ian Posted June 19, 2012 Share Posted June 19, 2012 hi, i am looking at fitting 2 volt gauges to the 90 to monitor the 2 optima batteries but when i look at info on fitting a gauge the concensus is they wire to the ignition and not the battery but i want to monitor both batteries so does anyone know of a way to do this? would prefer to use gauges if possible. Quote Link to comment Share on other sites More sharing options...
M&S Posted June 19, 2012 Share Posted June 19, 2012 I fitted an ON-OFF-ON switch, wired directly to each battery and then to a digital display. Simple as that really. You have to toggle between them but that doesn't matter does it? Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted June 19, 2012 Author Share Posted June 19, 2012 was actually thinking of linking each battery to a kill switch for added security so could maybe use that idea but via the kill switches if possible Quote Link to comment Share on other sites More sharing options...
western Posted June 19, 2012 Share Posted June 19, 2012 got 2 VDO voltmeters in my 110, one replaced the factory fitted LR gauge [it's a 110 County] the 2nd monitors my 2nd Odyssey battery for the winch, I wired the 2nd batt voltmeter via a 4 pin 30amp relay & it's ign controlled, so the gauge switches off when ign is off. here's how my relay is wired, the note at the bottom refers to the pre Td5 dash warning light panel. Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted June 19, 2012 Share Posted June 19, 2012 I've done the same as M&S. One side of the switch is fed from the ign, for the main battery. The other side is fed from the front winch isolator. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted June 19, 2012 Author Share Posted June 19, 2012 so forgive me if im wrong but are we saying i could run the main battery's meter through the ignition and the auxilliary's from the isolator switch?? Quote Link to comment Share on other sites More sharing options...
western Posted June 19, 2012 Share Posted June 19, 2012 main battery voltmeter on my truck is wired into one of the ign controlled White wires as LR did, 2nd voltmeter is wired as per my diagram above, you could go from the isolator switch to voltmeter but you'll only see that voltage when the isolator is switched on. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted June 19, 2012 Share Posted June 19, 2012 1 gauge, 1 on - on switch and an ignition switched relay on the gauges earth works for me. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted June 19, 2012 Author Share Posted June 19, 2012 thanks western, that sounds like the way forward for me, now just need to decide on gauges, any recomendations welcomed Quote Link to comment Share on other sites More sharing options...
Sirocco Posted June 20, 2012 Share Posted June 20, 2012 or buy a National Luna twin volt meter. uses LEDs, connect straight to battery terminals via a mini blade fuse and you can turn it on/off at the instrument face and even have an alarm on 1 or both when voltage drops into the red. All wiring included to. Its been great for the last 4 years. G Quote Link to comment Share on other sites More sharing options...
mmgemini Posted June 20, 2012 Share Posted June 20, 2012 or buy a National Luna twin volt meter. uses LEDs, connect straight to battery terminals via a mini blade fuse and you can turn it on/off at the instrument face and even have an alarm on 1 or both when voltage drops into the red. All wiring included to. Its been great for the last 4 years. G Until it goes wrong in the bush. Three days lost. I will try to sit on my hands where that company is concerned. I thried the three way switch on my twin battery set-up. For some reason it didn't work.... Now I have a volt meter on the main battery and an Engel switch/ volt meter/ low battry cut off fitted. Works fine. Quote Link to comment Share on other sites More sharing options...
Sirocco Posted June 20, 2012 Share Posted June 20, 2012 Until it goes wrong in the bush. Three days lost. I will try to sit on my hands where that company is concerned. I thried the three way switch on my twin battery set-up. For some reason it didn't work.... Now I have a volt meter on the main battery and an Engel switch/ volt meter/ low battry cut off fitted. Works fine. you must be refering to the 'kit' there Mike. The voltmeter wont stop anything by itself. You can buy them on their own for around £50. G Quote Link to comment Share on other sites More sharing options...
tacr2man Posted June 20, 2012 Share Posted June 20, 2012 Do make sure they are switched , as they will flatten battery if left on Quote Link to comment Share on other sites More sharing options...
western Posted June 20, 2012 Share Posted June 20, 2012 thanks western, that sounds like the way forward for me, now just need to decide on gauges, any recomendations welcomed I have 2 VDO Vision 8 to 16 voltmeters, bought from Europa Spares these https://www.europasp...332010001_.html Quote Link to comment Share on other sites More sharing options...
