eddie c Posted August 29, 2006 Share Posted August 29, 2006 My 8274 brake assembly fell to bits at the weekend, the circlip that keeps it all together failed, I managed to find all the bits apart from the circlip. Does any one know what size or part number this would be and would I be able to get it from local factors. ED Quote Link to comment Share on other sites More sharing options...
SteveG Posted August 29, 2006 Share Posted August 29, 2006 My 8274 brake assembly fell to bits at the weekend, the circlip that keeps it all together failed, I managed to find all the bits apart from the circlip. Does any one know what size or part number this would be and would I be able to get it from local factors.ED Warn part no. is 35028. Don't have one to hand anymore to measure it up for you, but hopefully someone else can help. It has to be fitted with flat side towards the brake assembly or it can come off. One way to stop it is to mod like Gwyn Lewis suggests for his heavy duty brake pads. See here... http://www.gwynlewis4x4.co.uk/page48.html Cheers Steve Quote Link to comment Share on other sites More sharing options...
white90 Posted August 29, 2006 Share Posted August 29, 2006 call Phil at PG winches he'll send you the correct item or Jim at Gigglepin 4x4 did you find all 21 bearings then? Quote Link to comment Share on other sites More sharing options...
eddie c Posted August 29, 2006 Author Share Posted August 29, 2006 Yes I found all the bearings and all the rest of the bits, but I think the spring came off at speed and could have been anywhere. I will be doing the same modification as show on Gywn Lewis site once I get a new circlip. ED Quote Link to comment Share on other sites More sharing options...
gsr341 Posted August 29, 2006 Share Posted August 29, 2006 eddie c im not using the circlips on mine , should have one at home (brand new), will cheak when i get home tommorrow , if theres one there its yours mate regards Dafydd Quote Link to comment Share on other sites More sharing options...
eddie c Posted August 29, 2006 Author Share Posted August 29, 2006 Thanks Dafydd. When you say you are not using yours, does that mean if you drill and tap the shaft, use a bolt and two washers you don't need to use the clip? ED Quote Link to comment Share on other sites More sharing options...
gsr341 Posted August 29, 2006 Share Posted August 29, 2006 ive drilled and tapped the shaft (bloody hard by the way , cobolt will not tuch it , tugsten does a bit !! ) and machened up a spacer thats counter bored fits over the shaft to the far end of the circlip grove , rather than use sum thing to hold the circlip , will try put a pic up tommorrow , show you what i mean , but my circlip is there from the service kit i fitted and as long as i can find it your welcome to it Quote Link to comment Share on other sites More sharing options...
Ex Member Posted August 29, 2006 Share Posted August 29, 2006 Really?? I drilled mine with a cobalt bit and had no problems whatsoever. I left the clip on. Quote Link to comment Share on other sites More sharing options...
gsr341 Posted August 30, 2006 Share Posted August 30, 2006 Ed C PM me your address i found a circlip , and the circlip fitting instructions regards Dafydd Quote Link to comment Share on other sites More sharing options...
eddie c Posted September 2, 2006 Author Share Posted September 2, 2006 Thanks Dafydd, I received the clip today. I think I will do one of the modifications to keep it on. ED Quote Link to comment Share on other sites More sharing options...
gsr341 Posted September 2, 2006 Share Posted September 2, 2006 no problem mate your welcome thats what this forum is meant to be about , helping one another out Quote Link to comment Share on other sites More sharing options...
