tukko Posted July 24, 2012 Author Share Posted July 24, 2012 Hummm something with the uploader Quote Link to comment Share on other sites More sharing options...
tukko Posted July 24, 2012 Author Share Posted July 24, 2012 Does anyone know if there's a seal between the engine and flywheel housing? I can't find anything about it. I'm not a fan of sealant Quote Link to comment Share on other sites More sharing options...
western Posted July 24, 2012 Share Posted July 24, 2012 No gasket shown or listed in any of the parts info I have for the 2.5 TD engine, only one for the 200tdi. workshop book says, if there is a O ring seal fit a new one, on later engines with no O ring use a bead of Loctite 518 sealant 5.5mm wide x 0.25mm thick, it does give a full size bead pattern diagram to aid with the bead location on backplate. Quote Link to comment Share on other sites More sharing options...
tukko Posted July 24, 2012 Author Share Posted July 24, 2012 No gasket shown or listed in any of the parts info I have for the 2.5 TD engine, only one for the 200tdi. workshop book says, if there is a O ring seal fit a new one, on later engines with no O ring use a bead of Loctite 518 sealant 5.5mm wide x 0.25mm thick, it does give a full size bead pattern diagram to aid with the bead location on backplate. Thank you! Sealant it will be then! Quote Link to comment Share on other sites More sharing options...
gruntus Posted July 25, 2012 Share Posted July 25, 2012 Thanks for the update Tukko. Cleaning and reasembling is very satisfying isnt it! Must be a bloke thing, my Mrs never seams to be too impressed........ All the best. G Quote Link to comment Share on other sites More sharing options...
tukko Posted July 28, 2012 Author Share Posted July 28, 2012 Tomorrow i'll start with putting everything back in place. Pistons and new rings are allready back inplace. I'll will make pictures tomorrow. Quote Link to comment Share on other sites More sharing options...
Daan Posted July 28, 2012 Share Posted July 28, 2012 Hi Roy, With regards to the crankseal and seal between block and flywheel house, please read this: http://forums.lr4x4.... +seal +problem I know it is a tdi, and yours is a td, but I use a td flywheel housing and this is now working well. Met hartelijke groeten, Daan Quote Link to comment Share on other sites More sharing options...
tukko Posted July 28, 2012 Author Share Posted July 28, 2012 Hey Daan thanks for the comment. I've got both seals genuine landrover and aftermarket. Last time i replaced the seal with a aftermarket one and was still leaking. But the problem was probably caused by to much axial clearance. Because there is no gasket between the engine and flywheel house, i will use silicone seal. It's the red one that holds up to 400*C . Your idea is perfect with the gasket but i cant get it for tomorrow. We'll see how it goes tomorrow. Monday is the next update with pica's Thanx again, Groeten uit Enschede Quote Link to comment Share on other sites More sharing options...
tukko Posted July 30, 2012 Author Share Posted July 30, 2012 Good morning all. The engine is ready. A few small things need to be done. I'm happy that i'm this far. It was a lot of work and i must admit that i underestimated it. Here some photo's at some stages. Quote Link to comment Share on other sites More sharing options...
Stevie D Posted July 30, 2012 Share Posted July 30, 2012 How did you get it so clean - ultrasonic cleaner or something? Nice workshop with the fire appliances in the background lol... Quote Link to comment Share on other sites More sharing options...
tukko Posted July 30, 2012 Author Share Posted July 30, 2012 How did you get it so clean - ultrasonic cleaner or something? Nice workshop with the fire appliances in the background lol... I wish we had a ultrasonic cleaner. All done by hand with a metal brush on a grinder and a lot of break cleaner And the garage is great. Very happy with that Quote Link to comment Share on other sites More sharing options...
tukko Posted July 30, 2012 Author Share Posted July 30, 2012 Small question! The cylinder head is skimmed. I was reading in a few topics about thicker gaskets. Do they also exist for a TD engine i can't find anything and is it necessary? The deck is not skimmed. For the replacement i used a after market standard metal gasket. Actually, the question is do i need a thicker gasket because the head is skimmed in relation ship to the heat stress of the engine Quote Link to comment Share on other sites More sharing options...
western Posted July 30, 2012 Share Posted July 30, 2012 only 1 head gasket for a TD engine listed, item 10 in http://www.numcat.ru/landrover/p/31/53104/ looks like this http://www.lrseries....ch=turbo&page=1 Quote Link to comment Share on other sites More sharing options...
tukko Posted July 30, 2012 Author Share Posted July 30, 2012 only 1 head gasket for a TD engine listed, item 10 in http://www.numcat.ru/landrover/p/31/53104/ looks like this http://www.lrseries....ch=turbo&page=1 Ok thanks, there is only one size. I asume i've got the right gasket that's the metall one. According to what Les said about metall gaskets and composite gaskets! Quote Link to comment Share on other sites More sharing options...
western Posted July 30, 2012 Share Posted July 30, 2012 I'd go with the info Les posted, my TD died over 15 years ago. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted July 30, 2012 Share Posted July 30, 2012 I'd go with the info Les posted, my TD died over 15 years ago. died? in 6 years? Quote Link to comment Share on other sites More sharing options...
western Posted July 30, 2012 Share Posted July 30, 2012 yep, as I had the money available I chose a new 200tdi instead of spending lots on a engine rebuild that would need doing again a few years further on, my 200tdi has been much more reliable & miles better to drive/live with. Quote Link to comment Share on other sites More sharing options...
tukko Posted July 31, 2012 Author Share Posted July 31, 2012 He guys, I'm looking for a intercooler. Is there a minimum size that i should look for. What is the best place to build it in? thanks Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted July 31, 2012 Share Posted July 31, 2012 He guys, I'm looking for a intercooler. Is there a minimum size that i should look for. What is the best place to build it in? thanks If you can get a 200TDi rad and intercooler together you'll be well away. Quote Link to comment Share on other sites More sharing options...
tukko Posted July 31, 2012 Author Share Posted July 31, 2012 If you can get a 200TDi rad and intercooler together you'll be well away. Is'nt this radiator smaller? Will it cool the engine enough? Quote Link to comment Share on other sites More sharing options...
reb78 Posted July 31, 2012 Share Posted July 31, 2012 Is'nt this radiator smaller? Will it cool the engine enough? That would be my question too. If you were worried about cooling capacity (which i would be with this engine), you could fit an M&D uprated 300tdi rad (it has an uprated core), that will in turn give you the space to fit a 'standard' intercooler next to it. They will do a 200tdi one if you send them the side tanks in the first place, but i'm not sure that is an issue as you would have to fabricate pipework for either. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted July 31, 2012 Share Posted July 31, 2012 Is'nt this radiator smaller? Will it cool the engine enough? it'll cool a TD engine fine. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted August 1, 2012 Share Posted August 1, 2012 My Series rad used to keep the TD cool, with a little help on very rare occasions from the leccy fan....before it fell off.... Quote Link to comment Share on other sites More sharing options...
tukko Posted August 2, 2012 Author Share Posted August 2, 2012 If you can get a 200TDi rad and intercooler together you'll be well away. IS there somebody on the forum that has a spare and is willing to sell it to me and send it over to Holland? Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 2, 2012 Share Posted August 2, 2012 I have a spare standard intercooler if you end up sourcing the bits seperatley. I also have an old rad, but it needs a re-core, so may be more hassle to you than its worth. In addition to those bits, you'll also need the frame that the whole lot fits in (i dont have one of those!). Quote Link to comment Share on other sites More sharing options...
