Rebuilding 2.5TD
Yes!
You need to remove the top coolant hose and top intake hose linking the top of the radiator/intercooler with the top of the engine, remove the viscous fan and it should slide in. You could also remove the air filter housing to make a little bit more room to thread it in.
Steve
Yes!
Steve
Ok, so the fan has come off as well. Thanx
Haha! I just bent my cowl in - I couldn't be bothered to remove the rad hose. It will just about bend and squeeze in without breaking (with only the viscous fan removed), but better to remove the hose if you can! :)
  • 8 years later...
