Warthog Posted August 31, 2006 Share Posted August 31, 2006 Just a quick question.... Any of you running Simex or Insa Turbo (simex ET tread) Find that on road the braking is pretty poor? I assume that it is the agressive tread pattern versus rubber contact on the road? I need to give it a good push to come to a halt sharpish? Disc/Pads are pretty fresh by the way Cheers Quote Link to comment Share on other sites More sharing options...
Divster Posted August 31, 2006 Share Posted August 31, 2006 Just a quick question....Any of you running Simex or Insa Turbo (simex ET tread) Find that on road the braking is pretty poor? I assume that it is the agressive tread pattern versus rubber contact on the road? I need to give it a good push to come to a halt sharpish? Disc/Pads are pretty fresh by the way Cheers I don't think the tread makes that much of a differance. Bear in mind that the tyre sizes for these patterns are alot larger than the standard fitment for a LR. (Even a 265 Insa Turbo is a fair bit taller than your standard fitment 265.) Quote Link to comment Share on other sites More sharing options...
