Pastycrimper Posted July 26, 2012 Share Posted July 26, 2012 Hmmmpf having been away working for weeks I get home and the ol man has a mission to gather a friends non-road worthy caravan full of stuff using a 3.5t vehicle trailor. She started perfectly after sitting for 6 weeks which was good. Somewhere about 20 miles, after pushing the clutch down and lifting my foot the pedal stayed frimly stuck to the floor. Using the upper foot the pedal could be dislodged back up but this made for awkward gear changes. The pedal sounds pretty creaky but the clutch itself functions fine. I took to just depressing the clutch just past the engaged point but still annoying. Sprayed some WD40 on the spring but hasn't done nought and if fully depressed will stay down. Any clues? Ended up being a testing journey home with a poorly balasted old caravan ona havy trailor on the Cornish hills with a sticky clutch pedal. Quote Link to comment Share on other sites More sharing options...
jbs Posted July 26, 2012 Share Posted July 26, 2012 Sounds to me like your master cylinder is shot, Is there the usual brake/clutch fluid in the footwell? If so this would confirm the master cylinder has gone or when you would be able to remove a wading plug from the bell housing(If you have one), Is there brake/clutch fluid leaking out of there If so that'll be the slave cylinder gone and to be honest If one goes then the other isn't that far behind and you're better off changing the both of them at the same time(for peace of mind if any thing) with either genuine or a good after market such as Bearmach etc-obviously stay away from Br****t as this'll cause you even more grief This is a norm for a Land Rover they need to be used regularly so that they won't go and do things like this when you most need them John Quote Link to comment Share on other sites More sharing options...
Diff Posted July 26, 2012 Share Posted July 26, 2012 Could be the clutch pedal pivot is seizing up? Take the top cover of the clutch pedal box under the bonnet and get plenty of oil on the pivot pin and bushes. If it isn't the pedal pivot, it could be either the master cylinder, or the slave cylinder. Regards, Diff. Quote Link to comment Share on other sites More sharing options...
Pastycrimper Posted July 27, 2012 Author Share Posted July 27, 2012 Cheers! Well if it isn't a knackered pedal pivot and is the more likely cyclinder issues I'm glad the old baby made it home before totally packing in. Quote Link to comment Share on other sites More sharing options...
Pastycrimper Posted July 27, 2012 Author Share Posted July 27, 2012 I don't reckon its either of the cylinders - well there's no sign of fluid leak and as I said the clutch works fine. I'm thinking it may be the pivot - I'll take it out and examine. Quote Link to comment Share on other sites More sharing options...
sharkey964 Posted July 28, 2012 Share Posted July 28, 2012 My pivot pin used to creak like mad,never stuck down though.I lubed it and it's now smooth and quiet.Happy days. Quote Link to comment Share on other sites More sharing options...
Steve King Posted July 28, 2012 Share Posted July 28, 2012 Is there a "squoink" noise?? If so then it is almost certainly the master cylinder, if not then pivot pint. BTW if it is the master cylinder, then get a genuine one! Quote Link to comment Share on other sites More sharing options...
discomikey Posted July 28, 2012 Share Posted July 28, 2012 more than likely your pedal pivot. mine is not sticky but needs lubrication. i saw somewhere on here someone put a grease nipple into theirs as it can be a reoccuring problem if stood for long times Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 28, 2012 Share Posted July 28, 2012 If there is no sign of leaking fluid that doesn't mean its not a FUBAR master or slave. There was no sign of leaking from my slave when it died with the same problem. Have you looked at the fluid level in the reservoir? Quote Link to comment Share on other sites More sharing options...
g90 Posted July 28, 2012 Share Posted July 28, 2012 i had the same problem, in my case it was the pivot http://forums.lr4x4.com/index.php?showtopic=71173#entry607557 Quote Link to comment Share on other sites More sharing options...
Pastycrimper Posted July 29, 2012 Author Share Posted July 29, 2012 Is there a "squoink" noise?? If so then it is almost certainly the master cylinder, if not then pivot pint. BTW if it is the master cylinder, then get a genuine one! There is a squoink but surely if the master cyl was screwed then my clutch wouldn't work? Quote Link to comment Share on other sites More sharing options...
Steve King Posted July 29, 2012 Share Posted July 29, 2012 The noise is air getting past the seal. It will get probably get worse... Quote Link to comment Share on other sites More sharing options...
discomikey Posted July 30, 2012 Share Posted July 30, 2012 There is a squoink but surely if the master cyl was screwed then my clutch wouldn't work? to me that would suggest pivot. however could be the master. a screwed master could still work. i had a known screwed slave for a month, leaking etc, and one day, just as i pulled back into my yard with flatbed + TE20 on the back, it went PFFT. and dropped all its fluid on the spot.. Quote Link to comment Share on other sites More sharing options...
G4FUJ Posted July 31, 2012 Share Posted July 31, 2012 I thought the "squoink" was normal LR clutch pedal operation - I think every Landie I've owned had it to a greater or lesser degree... Lubricating the pedal pivot doesn't seem to quieten things down for very long... Quote Link to comment Share on other sites More sharing options...
discomikey Posted July 31, 2012 Share Posted July 31, 2012 no, it just seems to return, which is why when i saw one with a grease nipple put onto it, i was quite interested. how sad is that... Quote Link to comment Share on other sites More sharing options...
G4FUJ Posted July 31, 2012 Share Posted July 31, 2012 My '76 Morgan has grease nipples on the pedal pivots... Maybe it's the only way to quieten a Landy clutch pedal? Quote Link to comment Share on other sites More sharing options...
