Turbocharger Posted September 1, 2006 Share Posted September 1, 2006 I'm contemplating a swivel rebuild this weekend, and I've read Les's excellent Tech archive run down. I've got 300Tdi axles on my Ninety, but I'm sure I remember doing this job before with a big Railko pin and cup arrangement in the top of the swivel, although that might have been on the original 1984 axles. Save me stripping it down then needing a return trip to the parts shop - which arrangements should 24-spline axles have? Pics stolen from Les's thread, showing the 2x taper-roller bearing arrangement. When there's a conclusion to this, can we add it to the Tech thread? Les says that all axles are much the same in his text, but I don't think that's quite true for the top pin. Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted September 1, 2006 Share Posted September 1, 2006 Yes, correct, two taper roller bearings ……….be aware that the bottom swivel pin has a habit of wearing ……….. Grease or oil ? and yes, correct, railko in the older 10 spilne axles. Ian Quote Link to comment Share on other sites More sharing options...
Paul Posted September 1, 2006 Share Posted September 1, 2006 As I understand it, 24 spline axles, rear disc brakes and ventilated front discs with top & bottom roller bearings in the swivels, all arrived at the same time - late 200Tdi. (At least, that's the way it happened in Aust.) Before that it was Railko top bearing, solid front discs, rear drums and 10 spline front axles. Paul Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 1, 2006 Share Posted September 1, 2006 I don't think that's quite true for the top pin. I've done a tech thread for the 300TDi hub assembly (twin taper roller pin bearings), and 200TDi 110 (railko top and taper roller bottom pin bearings) The title kinda gives it away - 'with the early railko-type bearing' Both are in the archive. Les. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted September 1, 2006 Author Share Posted September 1, 2006 My front discs aren't ventilated - are 110s different from Ninetys? It sounds like I've got a pair of bearings in the axle then, but might need a bottom pin too - I wonder if Christian Autos do 'sale or return'? Grease or oil - probably neither, it's not leaking at all... Quote Link to comment Share on other sites More sharing options...
simonb Posted September 1, 2006 Share Posted September 1, 2006 My 300Tdi 90 has taper bearings top and bottom, 24 spline shafts both end. I did the swivels a few days after Les posted his post. Front discs are solid unvented, IIRC 90 are unvented where as 110 are vented, more knowledgeable souls feel free to correct! Quote Link to comment Share on other sites More sharing options...
western Posted September 1, 2006 Share Posted September 1, 2006 not all 110's have vented front brake discs, my '90 110CSW didn't when built, but it has now after I fitted them some years ago. Quote Link to comment Share on other sites More sharing options...
LR90 Posted September 1, 2006 Share Posted September 1, 2006 I'm about to do my older railko bush hub amongst other front axle fixes and mods. The pins and the like are not expensive so I've now got a full set of spares ready to tackle the job and what I don't use will stay in my personal parts bin. Quote Link to comment Share on other sites More sharing options...
Paul Posted September 1, 2006 Share Posted September 1, 2006 My front discs aren't ventilated - are 110s different from Ninetys? It sounds like I've got a pair of bearings in the axle then, but might need a bottom pin too - I wonder if Christian Autos do 'sale or return'?Grease or oil - probably neither, it's not leaking at all... Ah...forgot about the difference between 90s & 110s. Sounds like the later 90s still made do with solid front discs like the early 110s. Paul Quote Link to comment Share on other sites More sharing options...
