petrolhead63 Posted August 1, 2012 Share Posted August 1, 2012 usual thing, both sunroofs are leaking a bit, only from certain angles. Parked forward down a hill no leaks, If it faces up the hill it pours in the rear one and dumps a load on the gear lever the first time you hit the brakes after setting off ;0) My only question is, how do they remove? do I need strip the whole headliner out?? They are manual versions on a millenium TD5. Quote Link to comment Share on other sites More sharing options...
dooroy Posted August 2, 2012 Share Posted August 2, 2012 When I sorted mine about 2 yrs ago I took out the headlining completely ( its all one piece ) and then refitted grab handles . I then drove the Disco for about 2 wks to get a good idea of where leaks were . Then I removed both sunroofs . There are about 14 ( I think ) torx headed screws keeping each frame in place . Some of these can be rusty and and cause problems - maybe a good dousing with penetrating oil beforehand would help . You can then lift out each sunroof having disconnected the drain tubes from the front of each . Be careful removing the tubes or you could snap off the plastic part they are attached to . Make sure pipes are clear . Make sure seal between each box and sunroof frame is intact ; if not clean everything off and reseal ; when replacing the sunroofs put a good bead of something like Silkaflex or Tiger Seal between frame and roof ; leave to set . Having resealed the roofs I didn't replace the headlining for another 2 wks to make sure it was all dry . When happy with repair replace headling . There is a good how to somewhere - if I find it will post a link . This is one :http://www.is-us.co.uk/vehicles/sunroof-repair-02.html Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted August 18, 2012 Share Posted August 18, 2012 I just lowered the front part of the head lining out as it was just the front sunroof leaking. I had a perished seal around the sunroof to body and a snapped drain tube above the driver seat. I was surprised at how easy a job it was to do. See this thread http://forums.lr4x4.com/index.php?showtopic=77630 Quote Link to comment Share on other sites More sharing options...
martinthehack Posted August 21, 2012 Share Posted August 21, 2012 My lovely TD5, amazingly, leaks like a sieve when it rains. You would have thought Land Rover would have fixed this problem, bearing in mind the series 2 cost about £30k. However, I haven't the time or the competence to repair the leaks, but I have been told there is a place in Essex that does repair Disco sunroofs. Does anyone happen to know who they are. If so, please share the information, I'd be soooo grateful, cheers Martin Quote Link to comment Share on other sites More sharing options...
