Turbocharger Posted August 10, 2012 Share Posted August 10, 2012 I bought a 12v compressor after seeing good reviews on here. What's this fitting it came with then? I'm more familiar with the left-hand two - PCL and Euro(?) fittings - but the one on the right came with the compressor and doesn't fit anything else I've got. Quote Link to comment Share on other sites More sharing options...
Maverik Posted August 10, 2012 Share Posted August 10, 2012 I watch with interest as I had noticed this with the same compressor... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 10, 2012 Share Posted August 10, 2012 Ditto above(!) Was tempted to cut it off and stick on PCL. Quote Link to comment Share on other sites More sharing options...
Les Brock Posted August 10, 2012 Share Posted August 10, 2012 Series 13KA Interchagability with Rectus 03, Nitto Kohki 200, CEJN 314, 315 http://www.rectus.de/products/qcde_products/low_pressure/brasssteel/single_shut_off/13ka/ HTH Quote Link to comment Share on other sites More sharing options...
fozsug Posted August 10, 2012 Share Posted August 10, 2012 As Les said , but also available from Hyphose Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 11, 2012 Share Posted August 11, 2012 Lovely, thank you both Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted August 12, 2012 Author Share Posted August 12, 2012 Thanks guys, I'll need to buy/make a converter. I unscrewed the union from the compressor and its *very* slightly larger than 1/4 BSP. Quote Link to comment Share on other sites More sharing options...
Maverik Posted August 20, 2012 Share Posted August 20, 2012 Awesome Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 20, 2012 Share Posted August 20, 2012 Thanks guys, I'll need to buy/make a converter. I unscrewed the union from the compressor and its *very* slightly larger than 1/4 BSP. Might be NPT. Basicly the american version of BSP. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted August 21, 2012 Author Share Posted August 21, 2012 Correction - it's slightly SMALLER than 1/4 BSP - I'll head down to Pirtek or similar and get an adaptor I think, so I can convert it to 1/4BSP and use a PCL fitting. T-Max hose (bottom), 1/4 BSP male-male adaptor from Machine Mart (top): Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted August 21, 2012 Share Posted August 21, 2012 John I have just been doing this mod to my T-Max compressor in order to wire it in permenantly. Not sure if yours is the same but I had the same issue in that the coupler fitting in the handle is a bit smaller than 1/4" (it is metric I think). Anyway, I removed the carrying handle from the top of the compressor and then unwound the metal tube inside it (mole grips needed) from the top of the compressor and hey presto... that is a 1/4" bsp fitting on that end. Have now got extension and PCL fittings on it and when my pressure switch arrives it will be wired to a dash switch and used to run the diff lockers Quote Link to comment Share on other sites More sharing options...
ejparrott Posted August 21, 2012 Share Posted August 21, 2012 Is it a 12mm metric fitting? Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted August 21, 2012 Author Share Posted August 21, 2012 I'd looked at that but didn't unscrew it because I'd assumed the tube was important for cooling as well as convenient packaging. However, if it saves me buying another fitting... I'll have another look when I get home from work. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted August 21, 2012 Author Share Posted August 21, 2012 Mark - does your compressor look the same as mine, because I unscrewed that tube (how much sealant?!?) and mine ain't 1/4"BSP inside. I've now dismantled the whole thing and I'll take the remnants to Pirtek or similar tomorrow to get an adaptor. Looking at the threads it came with, they all look to be metric pitches: 1: head to relief valve: 13.77mm OD, 1mm pitch: 2: relief valve to cooling pipe: 13.73mm OD, 1mm pitch 3: cooling pipe to flexy pipe: 11.9mm OD, 1.25mm pitch (I've only got metric thread gauges so...) 4: 1/4"BSP fitting from Machine Mart: 12.75mm OD, 1.25mm plus half a thread in every 6 = 18.8 threads per inch. Should be 19 threads per inch - near enough. Any clues what 1, 2 or 3 might be? I guess 1 & 2 are probably the same within the margin of my measuring error (which is good because it'd mean I can keep the safety valve, which sounds attractive). Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 21, 2012 Share Posted August 21, 2012 3. will be 12mm x 1.25 mm. 1 and 2 will be the same thread... Are they tapered? 13.73 is 540 thou and that rings a bell in my head for a thread size, cant remember what it is though!! It could well be a UNF thread. Quote Link to comment Share on other sites More sharing options...
davie Posted August 21, 2012 Share Posted August 21, 2012 at risk of sounding daft and not knowing what i am talking about, does anyone know of a way/supplier/somebody looking for beer tokens in post, of a way to change out the current awful screw on fitting onto tyre valve on t max unit to the nice type that you push on and flip lever to lock (dont know name) that would mean it just gets posted to me? Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted August 21, 2012 Author Share Posted August 21, 2012 Watch this thread carefully for a few more days and I should have reached a solution with all the information you need to order and plug in anything from a tyre inflator to a spray gun! It's hard to see if they're tapered or not, I've only got five or six threads to work with. It was bad enough trying to measure the pitch! They do look suspiciously metric though, lets hope my diameters were a little way out and I can find a fitting to make it all work. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 21, 2012 Share Posted August 21, 2012 To use anything with a trigger you will need a tank...... Quote Link to comment Share on other sites More sharing options...
ejparrott Posted August 22, 2012 Share Posted August 22, 2012 M14 is my bet for 1 & 2 Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 22, 2012 Share Posted August 22, 2012 M14 is my bet for 1 & 2 very possible with it being a comercial fitting but it'd be a sloppy fit... Almost like i made it. Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted August 22, 2012 Author Share Posted August 22, 2012 Pirtek were unable to identify the threads, not M12/M14 because neither would screw on. So I took the simplest route, bought a firtree fitting and cut the rubber hose. It's about 8 or 9mm ID, but I've wrapped tape around the 6mm firtree I bought and it works ok. A complicated route to a homebrew solution when I was hoping it'd work straight off the shelf. It's giving >100psi against a blind pipe and holds 50psi pumping into a tyre at 30psi. In due course I'll get an airtank and a pressure switch but, for now, it's adequate for tyres and airbeds. Quote Link to comment Share on other sites More sharing options...
bongo321 Posted February 11, 2019 Share Posted February 11, 2019 Did anyone ever sort out these thread sizes . .???? Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 13, 2019 Share Posted February 13, 2019 I have a T-Max and it too had the awful screw-on fitting. I recently bough a lance type fitting (like on petrol station air pumps) and a suitable barb adaptor to fit into the rubber hose that the screw-in valve is attached to. It works perfectly and cost me just over $10 to get the parts at a US tools shop, so it isn't expensive. Quote Link to comment Share on other sites More sharing options...
bongo321 Posted January 15, 2020 Share Posted January 15, 2020 Old thread revival , But does anyone know the tyre valve thread size , Because you could screw a tail into the silly t-MAX screw-on valve and then a length of pipe onto that with a PCL valve fitting on the end . I still would like to make an adapter for the push connect fittings if it was ever worked out . Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 15, 2020 Share Posted January 15, 2020 10 hours ago, bongo321 said: Old thread revival , But does anyone know the tyre valve thread size.... Schrader valves do not use a standard thread size. It is specific to them. Quote Link to comment Share on other sites More sharing options...
