Baz2236 Posted August 11, 2012 Share Posted August 11, 2012 hi as per the title my trailer light on my dash is on all the time. I have no trailer connected and no towing electrics on my tow bar. any ideas where to start looking to get it switched off. it used to just flash once when I used my indicators but just driving home I noticed its always on the indicators are working fine. thanks. Quote Link to comment Share on other sites More sharing options...
western Posted August 11, 2012 Share Posted August 11, 2012 probably a faulty flasher unit, as that what supplies the current to it.. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted August 11, 2012 Share Posted August 11, 2012 take the bulb out? ½" square of black insulation tape? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 11, 2012 Share Posted August 11, 2012 Mine is also always on. Will look at getting a new flasher unit. Where are they on the car Western? do you mean the relay? Quote Link to comment Share on other sites More sharing options...
western Posted August 11, 2012 Share Posted August 11, 2012 flasher unit/relay , is or should be behind the fusebox metal plate. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted August 11, 2012 Share Posted August 11, 2012 I'm sure there's only wires behind mine Quote Link to comment Share on other sites More sharing options...
western Posted August 11, 2012 Share Posted August 11, 2012 should be attached to the side nearest bulkhead, along with the start/brake check relays. Quote Link to comment Share on other sites More sharing options...
Baz2236 Posted August 11, 2012 Author Share Posted August 11, 2012 ok I will look at getting a new flasher bout time, it stopped last time I went wading so I flushed it with wd and it worked again so I suppose it is about time it died. on the shopping list for billing tomorrow then. It is mounted behind the fuse box. Quote Link to comment Share on other sites More sharing options...
western Posted August 11, 2012 Share Posted August 11, 2012 PRC8876 here as an example http://www.lrseries.com/shop/product/listing/10027/PRC8876-RELAY-FLASHER-UNIT.html?search=FLASHER%20RELAY&page=1 Quote Link to comment Share on other sites More sharing options...
