PS_Bond Posted August 12, 2012 Share Posted August 12, 2012 Given a 1995 110 with disc brakes, what's the correct fitting kit for pads? STC1268 & STC1269 are the calipers, pads were STC1601 (now SFP000280), Paddocks do a kit for STC160 with a part number of PM1122, which doesn't seem to tally with anything. I've looked at STC8573 (Discos, front to KA supposedly) STC8574 (says it is for 90 rears only) STC8575 (looks a lot like what is fitted, but supposedly only for front vented - solid pins with split pins & springs) STC8576 (for front solid discs, so I guess that's a 90 again) STC8577 (synchro hub assembly) and RTC5001 It'll probably be Mintex pads that I use this time around, so I'm assuming there's no kit included. TIA! Quote Link to comment Share on other sites More sharing options...
western Posted August 12, 2012 Share Posted August 12, 2012 pad kit SFP000280 should include the retaining pins too, as shown http://www.lrseries....D-SET-REAR.html I have the same pad kit here at home [ Lockheed-Delphi part LP0777] complete with the retaining parts. the PM number is NOT a LR part number, must be a Paddocks stock number STC8575 retaining pin kit is http://www.lrseries.com/shop/product/listing/12642/STC8575-BRAKE-PAD-RETENTION-PIN-KIT.html?search=%20STC8575&page=1 Quote Link to comment Share on other sites More sharing options...
PS_Bond Posted August 12, 2012 Author Share Posted August 12, 2012 Many thanks (again...!) I see they actually mention that it doesn't have the parts kit now - **Note spec change, now no longer comes with fixings kit, STC8575 ** Quote Link to comment Share on other sites More sharing options...
PS_Bond Posted August 19, 2012 Author Share Posted August 19, 2012 Fitted the new calipers & pads yesterday; the kit STC8575 has pins that are quite a bit longer than the ones on the old calipers. They won't extend beyond the caliper, but they're free to move back & forth about 3/4". I'm guessing the longer pins really are for the vented discs? Quote Link to comment Share on other sites More sharing options...
western Posted August 19, 2012 Share Posted August 19, 2012 STC8576 is only the springs & split pins http://www.island-4x4.co.uk/front-brake-spring-clip-stc8576-p-2406.html STC8575 is for Fits vented disc brake models, front.http://www.lrseries.com/shop/product/listing/12642/STC8575-BRAKE-PAD-RETENTION-PIN-KIT.html?search=%20STC8575&page=1 you could cut them down & redrill the hole for R clip or split pins. Quote Link to comment Share on other sites More sharing options...
