How to identify a Rover SD1 flywheel ?
greenstream
AFAIK the SD1 flywheels were lightweight aluminium rather than the normal hefty LR steel versions. I seem to recall the clutch was smaller diameter than 90/110 clutch, but same as a series 4 cyl.
SD1 are thinner than a RRC one and they will take the correct size clutch.
There may be other considerations though.
SD1 manual cars are considered rare to get hold of (my engine was but I did not know about them it at the time) I did have a modified RRC flywheel anyway.
The RRC flywheel is significantly heavier offering a much better drive off road. My S1 will climb over a log bridige (across ways) at tickover even seemingly comming to a halt after dropping into and climbimg out of a gap without stalling. I doubt that an SD1 flywheel would do this.
On the road if giving it a raz changing up the RRC flywheel is a pain as the engine revs will not drop between gears which gives a huge kick in the back but knackers the gearbox.
So which is best? it Depends on if you want a fast(?) road car or great offroad car?
Hope this helps?
Marc.
SD1 flywheel you don't go "hnnngg" when you pick it up, and it makes the car much easier to stall when bimbling round off-road (that was my experience anyway). RR one is, as said above, about an inch thick in the main part, visibly thicker than the ring gear (toothed) section.
