western Posted September 1, 2012 Share Posted September 1, 2012 (edited) after doing a cylinder head gasket change on my 200Tdi [Defender spec] I had to drain/refill the cooling system, I moved the fan cowling to examine the rads rear face & found lots of dead fins, so huge gaps between the cooling fluid tubes, engine/cooling system has never overheated & is otherwise in good health your task is to advise on which is the best new radiator to go for, I don't want the Britpart plastic tank assembly, but if it turns out to be the only option I'll get one, Edited September 1, 2012 by western Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 1, 2012 Share Posted September 1, 2012 How about a recore Ralph. M&D will uprate the core if you send them your old unit. There was s thread on this a while ago, I'll dig it out when I'm not on my phone. Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 1, 2012 Share Posted September 1, 2012 Here it is (found it anyway) http://forums.lr4x4.com/index.php?showtopic=71503 It's initially about 300tdi rads, but I suspect the quality makes are the same for both. Quote Link to comment Share on other sites More sharing options...
western Posted September 1, 2012 Author Share Posted September 1, 2012 Thanks for the link Still got the previous rad in the garage, so I could get that re-cored without taking the 110 out of use, I've found a place near Roche just off the A30 that can recore it more local, but I'll find out how much M&D want & how much it'll cost me to post the old unit to them, it's flipping heavy. Quote Link to comment Share on other sites More sharing options...
Ibex94 Posted September 1, 2012 Share Posted September 1, 2012 I got mine recorded by a place in Avonmouth they had the recon unit on the shelf - from memory it was about £120 a year back. Rob Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted September 2, 2012 Share Posted September 2, 2012 I bought a 300tdi britpart one last year and it is all brass, not a bit of plastic anywhere on it. Quote Link to comment Share on other sites More sharing options...
western Posted September 9, 2012 Author Share Posted September 9, 2012 found place within cornwall, that can recore my old rad & take it as a part-exchange on a pre-recored item from their stock, so hopefully next week I can go fetch it, Quote Link to comment Share on other sites More sharing options...
nickr Posted September 9, 2012 Share Posted September 9, 2012 Hi Ralph... What about Camborne Radiators?... just around the corner from you. Looking at mine today as part of the conversion I'm thinking that I might get mine looked at before it goes in. Quote Link to comment Share on other sites More sharing options...
western Posted September 9, 2012 Author Share Posted September 9, 2012 Hi Ralph... What about Camborne Radiators?... just around the corner from you. Looking at mine today as part of the conversion I'm thinking that I might get mine looked at before it goes in. their shop by rail station is now flats & I don't know if they are still going or moved, still in various online phone directories though, but not in BT book/website . Quote Link to comment Share on other sites More sharing options...
western Posted September 21, 2012 Author Share Posted September 21, 2012 found place within cornwall, that can recore my old rad & take it as a part-exchange on a pre-recored item from their stock, so hopefully next week I can go fetch it, took old rad to Newquay Radiators at Victoria last Friday, intention was to part ex it for the 'in stock' item, but when I got there, the 'in stock' was no longer, it had become a sold radiator, but they took my old rad, recored pressure tested & painted it & I picked it up this afternoon, now in the house waiting to be fitted, the new core has more cooling tubes/area so should do a fine job, no plastic side tanks & was £144 inc VAT. me is Quote Link to comment Share on other sites More sharing options...
unclemicky Posted September 21, 2012 Share Posted September 21, 2012 Western Can you get your intercooler repaired useing that method ...while you have it off? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted September 21, 2012 Share Posted September 21, 2012 Western Can you get your intercooler repaired useing that method ...while you have it off? How do you think Alisport and the like make them? Quote Link to comment Share on other sites More sharing options...
western Posted September 21, 2012 Author Share Posted September 21, 2012 Western Can you get your intercooler repaired useing that method ...while you have it off? nothing wrong with the intercooler, that's all intact & working, it could probably do with an internal clean though. Quote Link to comment Share on other sites More sharing options...
