JST Posted September 5, 2006 Share Posted September 5, 2006 do you get the paint to stay on it,m want to paint mine black. Quote Link to comment Share on other sites More sharing options...
headhunter Posted September 5, 2006 Share Posted September 5, 2006 Use etch primer. Halfrauds sell it - u-pol ACID 8. Not cheap but does the job. John Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 5, 2006 Share Posted September 5, 2006 Like the man says ^^^^^^^^^^^^^^^^^^^^ etch prime, normal primer, then black. De-grease thoroughly first though. Les. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted September 5, 2006 Share Posted September 5, 2006 Use several thin layers, otherwise the paint tends to pool around the raised bits - then not dry out. Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted September 5, 2006 Share Posted September 5, 2006 Use several thin layers, otherwise the paint tends to pool around the raised bits - then not dry out. Small Gloss Roller does the job nicely if your not spraying Quote Link to comment Share on other sites More sharing options...
