4x4landy Posted October 2, 2012 Share Posted October 2, 2012 Ok I thought I blew a bulb on my passenger side but its a weird one . Fuse is good . Bulb is good . Getting 11.8v without the bulb in when I put the bulb in I get 0v reading ??? Am I missing something title obvious here tried it earthed direct to chassis / battery etc . Kinda lost here Quote Link to comment Share on other sites More sharing options...
ChrisB Posted October 2, 2012 Share Posted October 2, 2012 Likely the 11.8v is a high resistance path to earth. Have you checked with meter between bulb supply & battery negative terminal? Quote Link to comment Share on other sites More sharing options...
4x4landy Posted October 2, 2012 Author Share Posted October 2, 2012 No But I will right now as I'm in work being paid to ummm do ummm well yeah Quote Link to comment Share on other sites More sharing options...
4x4landy Posted October 2, 2012 Author Share Posted October 2, 2012 Get 10.5v direct to the battery Quote Link to comment Share on other sites More sharing options...
4x4landy Posted October 2, 2012 Author Share Posted October 2, 2012 I earth it direct to the battery with the terminal on the bulb and earth it to the battery and get no light was working earlier when I drove it to work . But I went to tow a transit it and the passenger headlamp decided not to work been working fine last 4 months etx never had a issue Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted October 2, 2012 Share Posted October 2, 2012 There is a connector on the bulk head for the lights as well as other things. I have a 200Tdi and there are 3 (I think) of these connectors. I had an issue with my lights and I traced it back to these being corroded. Sprayed a load of WD40 in there, unplugged and plugged back in a few times and all was OK. Might be worth a look at these before you start adding and removing wires at the bulb end... Quote Link to comment Share on other sites More sharing options...
ChrisB Posted October 2, 2012 Share Posted October 2, 2012 If you get 10.5v bulbholder --> battery, what do you get across the battery terminals? It sounds much like Tetsu0san says, that contacts in a connector are corroded giving high resistance connections. Just a thought - visually inspect the wiring around the bulb holder. The previous owner of my disco had installed high-wattage bulbs and with the poor contacts (which get reeeely hot) melted the wiring and plastic bits in the loom. Quote Link to comment Share on other sites More sharing options...
4x4landy Posted October 2, 2012 Author Share Posted October 2, 2012 Unplugged and re plugged the plugs and it works ! Think there was a load of moisture inside and walla works ! Need to put a flap over the plugs as its in my Lwt hybrid Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted October 3, 2012 Share Posted October 3, 2012 Good stuff. Quote Link to comment Share on other sites More sharing options...
