Mouse Posted October 11, 2012 Share Posted October 11, 2012 Hi all The vehicle in question is a 200tdi Disco with a 2in lift. at the moment i an running 265/75/16 on 7x16 mach 5s, i would like to go wider and fit 33/12.50/15s, however i am getting conflicting advice as to if i can do this mainly from firms that are selling the wheel and tyre packages, some say that i need 10 inch rims while others say that 8inch is o.k. what are your oppions please. Mouse. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted October 11, 2012 Share Posted October 11, 2012 Well given that a 265 ought to be fitted to a 8" wide rim, I'd say fit a 12.50 on a 10" rim. There are a lot more 10" wide rims to choose from at 15" dia than there are for 16" dia. I think if you plan to run 33" tyres, you will need to get the jigsaw out and trim your arches. There's a lifted 300Tdi D1 around the corner from my work, he runs 285/75x15 BFG ATs (33" dia approx) and has trimmed arches at the rearmost edges, front and back. Quote Link to comment Share on other sites More sharing options...
Boris113 Posted October 11, 2012 Share Posted October 11, 2012 I thought that a 265 tyre should be on a 7inch rim? Nonetheless, a 10 inch rim would be ideal for your 12.50s Quote Link to comment Share on other sites More sharing options...
Nigelw Posted October 11, 2012 Share Posted October 11, 2012 I thought closest metric was 315/75X15 to the above Its 50mm taller and 50mm wider, 10" as a matter of course, but watch out for your off setts as you could end up losing all lock if the centres are too far to the middle/outside edges!!! Although spacers may help if you cant get the exact offset you need. Quote Link to comment Share on other sites More sharing options...
Mouse Posted October 15, 2012 Author Share Posted October 15, 2012 Thank you It looks like i will be going for 10 inch rims then, just got a bit of conciern that they will fit under the rear arch o.k, also what offset do i need to look for ???. Mouse. Quote Link to comment Share on other sites More sharing options...
