smokeyone
series 3 transfer case removal
I am hoping someone on the forum can point me in the right direction.
I have the gearbox/transfer case out and on the bench but splitting the two apart has got me puzzled.
Looked through the manual and searched the web.
Overdrive removed & bottom cover plate from the transfer case off.
Small nut inside the transfer case removed
Speedometer drive housing removed
Five nuts or nuts & bolts removed from around the top of the transfer case connecting it to the gearbox
Removed the castellated nut from inside the case
What am I missing please ......
Share this post
Link to post
"Small nut inside the transfer case removed"
That should be plural. Remove the intermediate gear and shaft and it will reveal more to remove.
Todd.
Share this post
Link to post
I seem to remember you need to remove the intermediate gear to get to the last of the bolts/nuts.
Share this post
Link to post
Cheers, thanks very much to all, hidden nuts under gear once removed and link to pictures.
I do appreciate the help.
Share this post
Link to post
