Landy4ducks Posted October 19, 2012 Share Posted October 19, 2012 Been checking over my 1986 LR90 for squeaking and clunking noises and found the rear UJ needs replacing. Whilst inspecting that was also told about a Sacrificial Drive Flange on the wheels - checked the front and you can see some play when rotating the prop (axle is jacked up). Question? Is this the same as the Driving Member or Drive Flange? Been checking through Microcat and cant find any reference to Sacrificial flange. (screen picture attached) Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted October 19, 2012 Share Posted October 19, 2012 Part 16 is a Drive member. This is somewhat sacrificial Quote Link to comment Share on other sites More sharing options...
western Posted October 19, 2012 Share Posted October 19, 2012 drive member or drive flange = same thing, not heard or seen it listed as sacraficial, they are softer material than the harder drive shaft so the drive member spline do wear quicker than the shaft spline. Quote Link to comment Share on other sites More sharing options...
Landy4ducks Posted October 19, 2012 Author Share Posted October 19, 2012 thanks CwazyWabbit . Thanks Western Quote Link to comment Share on other sites More sharing options...
western Posted October 19, 2012 Share Posted October 19, 2012 put a splash of gear oil EP90 in the plastic end cap before refitting it, the splines will love you forever. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted October 19, 2012 Share Posted October 19, 2012 put a splash of gear oil EP90 in the plastic end cap before refitting it, the splines will love you forever. a blob of grease works for me, makes less mess too. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 19, 2012 Share Posted October 19, 2012 Grease here too. No shafts are good running dry Quote Link to comment Share on other sites More sharing options...
mmgemini Posted October 20, 2012 Share Posted October 20, 2012 Yes it's sacrificial. Although I suppose some people would think it's easier to remove the broken bits from inside a Salisbury diff then change the drive flange ! ! ! ! If you take the oil seal from inside the axle that Land Rover had fitted to the Salisbury. Then the diff oil will also lubricate the splines. Quote Link to comment Share on other sites More sharing options...
