Maverik Posted November 13, 2012 Share Posted November 13, 2012 I'm looking at putting a standard seat belt set-up in the truck and some of the original brackets are still in place but I think I'm missing some for the seat belt latch/button part of the assembly... I think the brackets I need are 395249... can anyone shed any light at all? Cheers Mav Quote Link to comment Share on other sites More sharing options...
western Posted November 13, 2012 Share Posted November 13, 2012 here you go http://www.brit-car....php?xProd=79764 http://www.lrseries....h=395249&page=1 it's a 109 or 110 LWB bracket not for a 90. item 2 page 1030 in http://www.retroanaconda.com/landrover/parts_books/110/10_trim_seats_stowage_accessories_p910-1075.pdf Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 13, 2012 Author Share Posted November 13, 2012 Hey Ralph, I'm stuggling to understand how the clicker is bolted down on the 90, can;t seem to find any details in any of the parts books... or am I totally missing something...? Quote Link to comment Share on other sites More sharing options...
western Posted November 14, 2012 Share Posted November 14, 2012 by 'clicker' do you mean the seatbelt stalk ? I'm noy 100% sure as I've never owned a 90, but it should be bolted to the rear of the seatbox & base of central bulkhead just inboard of the seats. Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 14, 2012 Author Share Posted November 14, 2012 Yeah sorry not very technical description yeah the seatbelt stalk, I just can;t work out how its meant to be linked to the chassis, will have to see if I can go snoop around somone's else's 90... Thanks for your help though Ralph. Mav Quote Link to comment Share on other sites More sharing options...
western Posted November 14, 2012 Share Posted November 14, 2012 your welcome, a look at another 90 would get you sorted. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 15, 2012 Share Posted November 15, 2012 There's a small bracket that bolts to the top of the a-frame crossmember, and then this pick up on the bottom of the tub. At this point in the tub there is an integral steel support that has the 7/16" nuts welded in it for the seatbelt bolts. Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 15, 2012 Author Share Posted November 15, 2012 There's a small bracket that bolts to the top of the a-frame crossmember, and then this pick up on the bottom of the tub. At this point in the tub there is an integral steel support that has the 7/16" nuts welded in it for the seatbelt bolts. You wouldn't happen to know what it looks like in a parts book would you? Quote Link to comment Share on other sites More sharing options...
western Posted November 15, 2012 Share Posted November 15, 2012 might be item 26 &/or 30 on page 797 http://www.retroanac...is_p794-923.pdf Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 15, 2012 Share Posted November 15, 2012 Yep, item 26. Two of, and they're handed R/L. Item 30 is a nut plate that bolts it to the small tab on the top of the a-frame crossmember Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 15, 2012 Author Share Posted November 15, 2012 ok, i've got those... but how does it connect to the seatbelt stalk, as that bracket bolts to the box section which is on the underside of the seatbox or the box section that sits just underneith the rear bulkhead... Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 15, 2012 Share Posted November 15, 2012 Have a look at this photo: Notice the two sort-of-triangular right-angled brackets in the middle of the front face of the underside of the tub. You can see the seatbelt stalks and the bolts coming through the brackets. The "item 26" brackets on top of the chassis bolt up to the rear face of these - sandwiching the lower part of the tub bulkhead (the hole is just visible on the outward end of the bracket's vertical face - filled somewhat with underseal in this picture). Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 15, 2012 Share Posted November 15, 2012 There's also the photo in this post: http://forums.lr4x4.com/index.php?showtopic=64336entry556021 Which shows the brackets jutting forward from the crossmember to the vertical face of the tub's bulkhead (and to the brackets behind that). Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 16, 2012 Author Share Posted November 16, 2012 Awesome!!! cheers James! that is exactly the kind of photos I was hopeing to see and of course! I couldn't work out why there were two holes per side!!!! but thats for the center seat lap belt!!! the fog clears, thanks for your help gentlemen once again. Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 16, 2012 Author Share Posted November 16, 2012 Ok got another question, said bracket is PN 395252, according to the parts diagram there is also a tie bar behind it MRC4885, is this in addition to... NRC9698? if so where does this bolt too? Quote Link to comment Share on other sites More sharing options...
western Posted November 16, 2012 Share Posted November 16, 2012 that bar is item 2 in http://www.allbrit.d...0508&SPRACHE=EN looks like required parts to me to stiffen the bracket against bending NRC9698 item 33 x 2 in http://www.allbrit.de/UNI.cfm?PAGE=764169&SPRACHE=EN#33 looks like the fit under the cross member at centre bulkhead fixings Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 16, 2012 Share Posted November 16, 2012 NRC9698 is just the nut plate used to attatch the bracket to the top of the gearbox crossmember: http://www.brit-car.co.uk/product.php?xProd=126532 As for MRC4885, I've never seen that fitted to a car. According to this page it is for soft-top vehicles: http://www.brit-car.co.uk/product.php?xProd=140642 Quote Link to comment Share on other sites More sharing options...
