JST Posted September 8, 2006 Share Posted September 8, 2006 the three that go on the brake shaft that is. Which way round do they go Dome part towards the centre of the winch or towards the outside. I am assuming the dome part to be the highest bit if they were placed on a flat surface. i think its dome towards the outside so that the circlip then pushes on the shims to apply extra force to the brake, the dome acting as a spring although it makes it harder to get the circlip in this way. i tried this way and watched the whole lot fly across the garage when tension was applied. with the dome towards the centre the outer edge of the dome then holds the circlip in place. this hasn't come apart by tensioning the hook onto the bumper (unlike above) but i think its the wrong way around! so which way do they go? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted September 8, 2006 Share Posted September 8, 2006 Can not understand........... Shims???? Brake rebuild with Pictures Partys Diagrams here The springs holds the brake open. The cam forces it closed. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted September 8, 2006 Share Posted September 8, 2006 Can not understand........... Shims???? Later ones have 3 'shims' that fit on the brake shaft before the circlip, unlike yours and mine which is the earlier design. The later one with the 'shims' also has a smaller OD end on the brake shaft and take a smaller circlip. The 'shims' are item number 50 spring disc x3 as listed in your second link. Quote Link to comment Share on other sites More sharing options...
white90 Posted September 9, 2006 Share Posted September 9, 2006 dome outwards on my one from brand new when I pulled it apart Quote Link to comment Share on other sites More sharing options...
TJ101 Posted September 9, 2006 Share Posted September 9, 2006 Get it right guys,, would hate to have it all "fly" to bits, going for that first punch !! Sorry James,, could not resist Quote Link to comment Share on other sites More sharing options...
white90 Posted September 9, 2006 Share Posted September 9, 2006 actually the third one it last ok for the first two Quote Link to comment Share on other sites More sharing options...
