Discovery 300 TDI fuel problems won't bring diesel through pump to
jay_jay92
hi all I had a problem with my fuel pump leaking, I managed to sort it but in the seal kit it didnt have the seals for the other spindle so i have had to strip it back down again and do that one.
I have had it running well from when I first put it back together
Now i have put it all back together from how i took it apart and same as last time now i cant seem to get diesel upto the injectors
I Have tryed priming it with the lift pump but that feels like its got pressure one minute then none the next
I have tryed a few things to bleed them i have also tryed bump starting it and using easy start to pull it through but it will not carry on running
put a new diese filter on today and tried putting the pipe in a bottle to try that and the lift pump seemed to be passing loads off diesel through so bit stuck on what to do
Also just tryed the injector pipes that run from pump to injectors no diesel coming through there
So it's feeding to the pump but not coming through the pump the injectors
Is there anythink I could off nocked or done wrong
What is the other shaft on the side off the pump that there is a bar that goes to the throttle
now im starting to get annoyed with it now
Also I have got a live to the solinoid to make sure it turns on
anyone got any ideas off what it could be or what to try or anyone that could help with what it is
thanks
Its not clear from your post, just to check, you are cranking the engine when bleeding from the FIP to the Injectors? Priming the lift pump alone will not push fuel through to the injectors. You need to crack open the fuel connections at each of the injectors then crank the engine until fuel leaks out, then re tighten the fuel connections and it should go.
