moondog74 Posted November 18, 2012 Share Posted November 18, 2012 Greetings all My 97 300tdi disco, when i turn the ignition on the "battery light" does not come on even when engine is running, i have a spare set of clocks which i have tried and still no light. so if anyone knows the problem please help thank you in advance Mark Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 19, 2012 Share Posted November 19, 2012 Alternator is probably farked, sometimes something goes inside them that means the warning light does not get powered. Check the voltage with a multimeter you should have 12.6-12.8v after it has been sitting overnight with no load, and it should rise quickly to 14.2-14.4v after starting. If it charges ok but just the light is broken, you might decide you can live with it, but more likely is that it isn't charging at all or not properly. Quote Link to comment Share on other sites More sharing options...
