yogibear47.lee Posted November 18, 2012 Share Posted November 18, 2012 hi all im after a decent recovery point for the rear of my discovery 1, i have a tank guard so im removing the tow bar so what a good recovery point for the rear. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted November 18, 2012 Share Posted November 18, 2012 Southdown guard and recovery eye. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted November 18, 2012 Share Posted November 18, 2012 If your tow plate removes with two pins then you can purchase a recovery point which fits the two pins. I don't know if you can still purchase these now. Steve Quote Link to comment Share on other sites More sharing options...
yogibear47.lee Posted November 18, 2012 Author Share Posted November 18, 2012 Southdown guard and recovery eye. sorry i have already got a tank guard so not looking to buy another If your tow plate removes with two pins then you can purchase a recovery point which fits the two pins. I don't know if you can still purchase these now. Steve i think they are bolted on Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted November 18, 2012 Share Posted November 18, 2012 You could fit a aftermarket rear bumper with recovery points. Im assuming the tank guard use's the bolt holes that the tow bar would normally use (?), thus making fitting jate rings difficult/impossible. Quote Link to comment Share on other sites More sharing options...
yogibear47.lee Posted November 18, 2012 Author Share Posted November 18, 2012 it was my old one i sold but i cant remember what it uses, i think it uses the same bolts what the standard tank guard/strap uses. Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted November 18, 2012 Share Posted November 18, 2012 If it doesn't use the two bolt holes in the 'dip' in the chassis rails where the tow bar supports bolt on, you could fit jate rings. However jate rings on a disco are hard to get at when your stuck. I would advise a well fitting aftermarket rear bumper with some professionally welded on recovery points. Also, its alright thinking your new rear bumper is well made, youve got to make sure the back of your chassis where the bumper bolts on is in good condition and up to the job of recovering you from situations you might get into. Id personally beef up the bumper mounting points, or infact add some extra's. Quote Link to comment Share on other sites More sharing options...
yogibear47.lee Posted November 18, 2012 Author Share Posted November 18, 2012 If it doesn't use the two bolt holes in the 'dip' in the chassis rails where the tow bar supports bolt on, you could fit jate rings. However jate rings on a disco are hard to get at when your stuck. I would advise a well fitting aftermarket rear bumper with some professionally welded on recovery points. Also, its alright thinking your new rear bumper is well made, youve got to make sure the back of your chassis where the bumper bolts on is in good condition and up to the job of recovering you from situations you might get into. Id personally beef up the bumper mounting points, or infact add some extra's. no i sure they didnt use them holes last time and i was hoping not to get a heavy duty bumper to be honest is there any way of making a rear point what strong enough. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted November 18, 2012 Share Posted November 18, 2012 i think they are bolted on I'm talking about the one half way down this page Steve Quote Link to comment Share on other sites More sharing options...
yogibear47.lee Posted November 18, 2012 Author Share Posted November 18, 2012 I'm talking about the one half way down this page Steve oh sorry no my tank guard is like this one http://www.paddockspares.com/pm1087-disco-1-fuel-tank-guard-galvanised-steel.html Quote Link to comment Share on other sites More sharing options...
dirtyninety Posted November 18, 2012 Share Posted November 18, 2012 Basically buy some jate rings OR a new tank guard with recovery points as Steve200tdi says. (imho the paddocks one is nothing more than a galv tank cradle) OR buy an aftermarket rear bumper. You've limited your choices somewhat buying that tank guard. Quote Link to comment Share on other sites More sharing options...
Green Bob Posted November 18, 2012 Share Posted November 18, 2012 Do the holes in a d1 bumper have crush tubes and line up with a NATO hitch? If so, one of those with spreader plates inside and out would be pretty much bombproof... Quote Link to comment Share on other sites More sharing options...
yogibear47.lee Posted November 18, 2012 Author Share Posted November 18, 2012 Basically buy some jate rings OR a new tank guard with recovery points as Steve200tdi says. (imho the paddocks one is nothing more than a galv tank cradle) OR buy an aftermarket rear bumper. You've limited your choices somewhat buying that tank guard. i had this one on my old disco and its strong enough and plus it was cheap to buy back, i'll look at a rear bumper or i'll get my dad to make something what uses the bumper bolt holes. Quote Link to comment Share on other sites More sharing options...
yogibear47.lee Posted November 18, 2012 Author Share Posted November 18, 2012 Do the holes in a d1 bumper have crush tubes and line up with a NATO hitch? If so, one of those with spreader plates inside and out would be pretty much bombproof... i dont no to be honest Quote Link to comment Share on other sites More sharing options...
Ratty43 Posted November 20, 2012 Share Posted November 20, 2012 YRM do a NATO hitch mount which bolts around the rear cross member using the two tow bar mounting holes. That seems to be the easiest option to me. Quote Link to comment Share on other sites More sharing options...
gazelle Posted November 20, 2012 Share Posted November 20, 2012 How about buying/fabricating a simple eye such as seen here on a defender? Quote Link to comment Share on other sites More sharing options...
SPendrey Posted November 21, 2012 Share Posted November 21, 2012 YRM do a NATO hitch mount which bolts around the rear cross member using the two tow bar mounting holes. That seems to be the easiest option to me. Yep, I bought one with the same issue in mind. Really solid bit of kit that just bolted over th rear cross member where the old tow bar was. It did require modification of the bumper to fit over it and expose any recovery tackle, but that was simple and cost effective. Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 21, 2012 Share Posted November 21, 2012 The camel Disco's have a 5t recovery eye bolted to the rear crossmember, its quite clever actually. I'll see if i can dig out the link. Mav Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 21, 2012 Share Posted November 21, 2012 Is it something like this Mav? http://www.overland-rovers.com/ralphs-pages/layout/vehicle-modifications/125-rear-recovery-socket.html#g_125_0 Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 21, 2012 Share Posted November 21, 2012 Ish... there is actualy a bracket that is welded to the rear chassis crosmember if memory serves, then there's is a cut out in the center of rear bumper, so effectivly the recovery "jaw" (dixon bate 5t revovery jaw) is bolted directly to the chassis.bypassing the bumper. I thought I recognised that wagon, tis "Ralphh" 's. Quote Link to comment Share on other sites More sharing options...
