reb78 Posted November 18, 2012 Share Posted November 18, 2012 As above. Can you get the rubber seal for the fuel filler cap (the big 'washer' with the rubber backing on it)? Mine is a 1989 110 if that makes any difference. I have had a look, but couldnt see it as a seperate part. I seem to have a permanent diesel mark down the rear quarterpanel (its not a lot, but is must loose a tiny bit when the tank is full and its sloshed around). Also, if i need to replace the cap, is mine the vented type? Quote Link to comment Share on other sites More sharing options...
western Posted November 18, 2012 Share Posted November 18, 2012 never seen it as a seperate part, mine could do with a new seal as well, Yes to a vented cap. Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 18, 2012 Author Share Posted November 18, 2012 Cheers Ralph. Might just have to get the cap. Seems silly since its only two screws to gain access to that washer though. Quote Link to comment Share on other sites More sharing options...
