rudd86 Posted November 18, 2012 Share Posted November 18, 2012 my 200tdi has got a line of black oil leaking from the head gasket area all around the top of the block, notibly more so under the turbo and at the back end, its not a massive leak but its annoying me as im wondering if im missing classic head gasket failure signs it has no water in the oil or vice versa, no mayo under filler cap and it doesnt use any water am I missing something or does this seem normal? it does seem a little down on power if im honest. if it is the head gasket starting to go, is it possible to re-torque the head bolts and see if it stops the leak or shall I just do it properly with the head off etc....? over to you guys. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted November 18, 2012 Share Posted November 18, 2012 Inlet manifold gasket ? Quote Link to comment Share on other sites More sharing options...
western Posted November 18, 2012 Share Posted November 18, 2012 might be a poor rocker cover & the half circular seals are leaking, easy to replace. Quote Link to comment Share on other sites More sharing options...
rudd86 Posted November 18, 2012 Author Share Posted November 18, 2012 which circular seals do you mean western? Quote Link to comment Share on other sites More sharing options...
western Posted November 18, 2012 Share Posted November 18, 2012 the 2 sit in the front & rear ends of cylinder head, item 26 x 2 in http://lrcat.com/#31/4/53143 Quote Link to comment Share on other sites More sharing options...
reb78 Posted November 18, 2012 Share Posted November 18, 2012 my 200tdi has got a line of black oil leaking from the head gasket area all around the top of the block, notibly more so under the turbo and at the back end, its not a massive leak but its annoying me as im wondering if im missing classic head gasket failure signs it has no water in the oil or vice versa, no mayo under filler cap and it doesnt use any water am I missing something or does this seem normal? it does seem a little down on power if im honest. if it is the head gasket starting to go, is it possible to re-torque the head bolts and see if it stops the leak or shall I just do it properly with the head off etc....? over to you guys. Mine is similar, but i think it is the rocker cover seal as Ralph suggests. On mine, performance is great (accelerates well, no white smoke and will sit at 85mph happily), no water or oil use and no water in oil or vice versa, so i dont think my HG has gone. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted November 19, 2012 Share Posted November 19, 2012 my 200tdi has got a line of black oil leaking from the head gasket area all around the top of the block, notibly more so under the turbo and at the back end, its not a massive leak but its annoying me as im wondering if im missing classic head gasket failure signs If the rocker cover gasket or rocker cover seals are leaking. Then why isn't there oil on the top of the head and the rocker cover ? ? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 19, 2012 Share Posted November 19, 2012 In the absence of pictures, I'd be inclined to go along with Uncle Mike and suggest the inlet manifold gasket, a common job on Tdis. Perhaps you could post some pictures up, that would help diagnosis. HTH Mo Quote Link to comment Share on other sites More sharing options...
