lawrence Posted November 21, 2012 Share Posted November 21, 2012 My 1995 disco 300 tdi has a problem at high revs, when acelerating upto 55-60 there is not problem, but trying to go any faster is an issue. The car seems to loose power for a moment and the revs will drop off, if you keep your foot down it will pull through but really struggles. My first through was fuel filter so that was changed but no improvment, could it be the fuel pump on its way out. Any advixce would be greatful, the car runs fine apart from this little issue and has just flown through its last MOT with no problems. Quote Link to comment Share on other sites More sharing options...
elbekko Posted November 21, 2012 Share Posted November 21, 2012 Yep, probably the lift pump. Quote Link to comment Share on other sites More sharing options...
lawrence Posted November 21, 2012 Author Share Posted November 21, 2012 okay thanks, do you know if its easy to replace. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted November 21, 2012 Share Posted November 21, 2012 Yes, but can be a bit fiddly around the injector pipes. The last one I did took about 20 mins. You might like to read this: http://forums.lr4x4.com/index.php?showtopic=79858 Quote Link to comment Share on other sites More sharing options...
