Body Alignment Issue.
ajh
I am fairly sure I know the answer; but if the rear tub is slightly too low in the front but fine in the rear corner so that the sides when bolted in place have a gap towards the front between them and the tub does this mean I need to loosen all the front tub fixings and shim it up into place to get things to align correctly?
If you mean a gap between the upper sides and the tub at the door junction then you just need to loosen the tub brakets at the front of the tub, jack it up (the tub that is) gently and it a suitable place, and re-tighten. There is some adjustment for height on the brackets, or there should be.
